Conveyor Belt
microzone
Feb 11, 2006
71
        Actually I need to create a conveyor belt to transfer a glass with water from one place to another place, distance is around 60cm. Is anyone has an idea to create a conveyor belt? Do you have the construction diagram? Thank you first for your kind help.  :)
ante1
Jan 24, 2004
4,138
Hi microzone,
Is it a must to use a belt? A conveyor transfer system can be built in different ways. Is it suppose to run in one direction only or do you like it to be reversible? Can you give some more details please?
logan_dslasher
Jul 23, 2004
392
microzone,
it would help a lot if you would tell what exactly is the purpose of the conveyor belt..  ;D
ante1
Jan 24, 2004
4,138
Maybe he’s a bartender, but then again ‘water’….  naa maybe not!  ;D
logan_dslasher
Jul 23, 2004
392
hi microzone!  ;D
yes, you've already mentioned those details in your first post.. the experts here i think need to know more what conveyor belt is suitable for you.. Ante asked you if is needs to run only in one direction, which you didn't answer.. they need to know more.. like..
how fast should it be?
does it need to have a Pause/Stop button ?
how many glasses do you intend to put in it at a time?
... etc
details like those would help picture out what is the most suitable conveyor belt you should build.. as ante have said
windoze killa
Mar 4, 2006
136
You could use stepper motors which will have more than enough power to move you glass full of water. They can be controlled to such an extent that you wouldn't spill a drop. You could have it so when you press the button it would start of slowly and slowly accelerate and then slow down again as it approaches the end. Also very easy to make it revesible.
microzone
Feb 11, 2006
71
    Thanks for all the elctronic experts kindly reply.  Actually I need to build a conveyor belt with a dc motor which will only work in one direction and the conveyor belt speed is optimum to avoid spill a drop and only 1 glass per time.  I plan to use PIC (a microcontroller) to stop the conveyor belt after the glass reach the destination.  Actually I only an electronic newsbies therefore I do not know how to build a driver to drive the motor further more the motor type (12V or other voltage) is also a problem for me. Do you know what kind of material can I use to build the conveyor belt? Can you give me some precious idea?
microzone
Feb 11, 2006
71
      Hi! Expert and non expert are welcome to give your idea on this because I really do not have an idea on the conveyor belt. Thanks.  :D
rybitski
Jan 9, 2006
161
how about some kind of moddified printer/scanner drive belt with a metal plate attached on the top to rest the glass on? So instear of tring to buy a belt wide enoungh for the glass use a thinner one...
Tony_Stoynov
Dec 20, 2005
197
you can made different construction. The traditional conveir belt is a one or two draving wheels, depend from this one or two direction is movement, and several secondary wheels between them. The belt can be set in motion with friction or with cogwheel.
In your case i think you can use cogwheel construction, from old donuts cooking machine, they use a cogwheel and mortiser belt. You can also made a simple construction with two pulley and wire. To drive the DC motor in only one directin you will need relay or transistor. To detect the position yu can use the optobarier sensors.
