Current Conveyor with high input voltages
Status
Not open for further replies.
PhilD
Aug 2, 2021
Master's freshman here! I am tasked with designing a current conveyor that can handle high voltages (about 5V) and am looking for an appropriate topology and transistors for the job. I think the following transistors: https://www.diodes.com/assets/Datasheets/DMC31D5UDJ.pdf would do it. The goal is to be able with the same circuit to simultaneously send voltages and receive currents to and from a device with varying resistance. The topologies I found online are designed to work with small bias currents and supply voltages. The attached is a topology I found but I can't get it to work (the input voltage is what the circuit needs to be able to handle). Any help would be appreciated. Y needs to be in the [0,5]V range, X will be of 1mA maximum. Thanks!
  • current_conveyor_OP2 - Copie.asc
BobWeHadABabyItsABoy
Dec 17, 2024
Did you ever did the manual for the Dick Smith Q-1240 oscilliscope? I know where to find one... if for some reason you're still looking for that information 20 years later.
Status
