morphingstar
- Mar 1, 2012
- 58
- Joined
- Mar 1, 2012
- Messages
- 58
I have some small circuit boards 40x40mm monitoring hall effect semiconductors. Whenever environment temperature goes >28°C the logic of the hall signals goes crazy. The output result comes from 3 synchronized elements. When the temperature rises - it is no longer the right ones, or an element signal might even be added, usually not lost. The hall magnets are moved mechanically in proper order, this can be seen. When the temperature goes below 28°C the craziness disappears, system works correct.
The circuit temperature goes close to 40°, where it is measurable, might be warmer in some poorly ventilate spot. I am considering a fan,but this will just blow the 28+ (e.g.31) air towards the components, though it may still have a good influence.
The circuitry is applied in a mechanical accordion, picking up the lever movements. The chord levers are coupled (sets of 3) to make a chord. When the chord sounds wrong the circuit has gone nuts or worse. This digital circuit is behaving worse than circuits in "old analogue days" where drift was a known problem and had known solutions.
Suggestions?
Suggestions?
