Cost to install 15A GPO?
N
Nick Adams
Afternoon guys,
I have purchased a used 1600W UPS that requires 15A GPO. I currently
only have standard 10A GPO's where the unit will be going.
As it stands now, all the gear that will be run off the UPS runs fine
off the one 10A GPO - three computers, no monitors and a bit of
networking gear. A very rough, completely over exaggerated estimation
they would draw 1400W.
The outlet is only 6M from the breaker board and is on the same circuit
as a home theatre system (large CRT TV, audio amp, Digital STB...etc),
microwave and other miscellaneous devices.
Two questions:
1/ I'm of the opinion that I shouldn't just run the UPS on the 10A GPO.
Is this technically correct? Given that the devices run fine now is it
one of those 'will probably work but don't do it' situations?
2/ If I have to install [wait, wait...if I have to pay a qualified
electrician to install] a new 15A GPO what is a rough guestimation of
cost? Likely factors include only 6M from the breaker board, there are
'spots' spare on the breaker board and I'm located in inner-north Brisbane.
Any replies greatly appreciated.
sam
Nick said:
Afternoon guys,
I don't know what the norm is for UPSes, but drawing 2400 to 3600 W and supplying 1600W doesn't
sound very efficient. Using the waste 800 to 2000W to heat the house in winter might help :)
3 average PCs and the network gear might draw 300W tops on average, probably less IMO. Maybe peaking
higher during disk activity, startup etc.
Two questions:
It probably wouldn't use anything like 10A in practice, so I'd put an 8 or 10 amp fuse in the UPS
and give it a go.
Cheers,
sam
Michael said:
Did you stop to think that when the batteries are charging, you may
still need full output for the regular load?
Yes, I did, thanks. Perhaps the batteries are charged at a higher current than I was expecting.
I'd still be giving it a go though.
Cheers,
Phil Allison
"Nick Adams"
I have purchased a used 1600W UPS that requires 15A GPO. I currently only
** What that indicates IS that when *fully* loaded and charging, the unit
draws in excess of 10 amps RMS continuous from the AC supply. So the makers
were compelled to fit a 15 amp plug to comply with regulations.
Is it the sort that runs 100% of the time ( ie a sine wave supply ) - or
only when AC supply is lost.
As it stands now, all the gear that will be run off the UPS runs fine off
the one 10A GPO - three computers, no monitors and a bit of networking
gear. A very rough, completely over exaggerated estimation they would draw
1400W.
** Bet it is not even half that.
The outlet is only 6M from the breaker board and is on the same circuit as
** IMO - that circuit is overloaded.
But all that will happen is the breaker in the power box will trip when the
" uW" is operated.
Two questions:
1/ I'm of the opinion that I shouldn't just run the UPS on the 10A GPO. Is
this technically correct? Given that the devices run fine now is it one of
** Yep.
......... Phil
N
Nick Adams
Phil said:
"Nick Adams"
Yes, it is an 'online' UPS and is supplying power from battery 100% of
the time.
I agree. That was more of a worst case scenario. I would rather
overestimate than underestimate.
They are not really average computers but rather servers. In total there
is about 12 HDD's between a few RAID arrays. Even then...your right.
Probably. My question is, how much additional load will the UPS take? If
I'm pushing it now how much closer does this bring me to breaking point
(pun intended)?
" uW" is operated.
** Yep.
Cool. Thanks Phil.
Phil Allison
"Nick Adams"
Yes, it is an 'online' UPS and is supplying power from battery 100% of the
time.
** That is not strictly true.
The batteries will normally be fully charged and "floating" while an
internal DC supply operates the 240 volt re-generator circuit. This DC
supply will need to do *two* jobs whenever there has been a recent AC
power outage, recharge the batteries AND run the 240 volt re-generator.
This is when the AC supply draw can exceed 10 amps RMS.
Your power circuit likely has a 16 amp breaker.
Now, the "uW" oven draws about 8 amps.
Add it all up.
Snap.
........ Phil
N
Nick Adams
Phil said:
"Nick Adams"
Add it all up.
Snap.
OK. Any idea of ballpark costs to add a new 15A outlet? I have no idea
if its closer to $100 or $1000.
atec77
anywhere between one and two hun' normally ) dont quote me 'till the
sparky looks) , depends on location and if it has certain hardware
availible . ( and room in your electrical box)
R1rob
Get a few installed at once if you need them.
1/3 of the fee is prolly appearance money.
Poxy
'Pends if you need a new circuit, which is sounds like you do. If so, you'll
be up for a new breaker and RCD if there isn't one already, and then there's
the effort involved in running the cable, and there's the cost of the
outlets. I'm guessing at least a couple of hundred, maybe $500 if it's a dog
of a job, maybe more if there's complications.
Get a recommendation for a good sparkie and give them a call.
To give you some idea, about a year ago I got 2 new circuits put on - I
supplied and ran cable, sparkie supplied RCD + 2 breakers and extra consumer
unit plus 1 double exterior GPO and 1 industrial single phase gpo - all up
cost about $400.
Mr.T
You don't know much about PC's then! A Pentium CPU by itself requires about
100W each. Have you ever wondered why a single PC power supply is rated at
300-500 Watts, or more? Maybe your "average" is for a 24 hour period where
the computers are turned off 2/3rds of the time?
MrT.
atec77
MrT.
I suspect you are suffering under a misapprehension as to the actual
consumption and power rating of a power supply , perhaps you might
investigate OHM'S law .
David Sauer
$100 for RCD/MCDB combo
$100 for cable, GPO, fixing etc.
$240 for labour
Of course its more economical to get a couple of other items done at
the same time if required.
Mr.T
I'm well aware of ohms law. You OTOH have no idea about modern PC power
requirements when they are actually working.
Or maybe you are claiming to have a PC power supply with greater than 100%
efficiency??
MrT.
K
Kr
it depends on what is involved in the 6 metre cable run, if its just
going to be put on the wall in a conduit (or just tacked on a timber
wall), its going to be a lot less effort than if it has to go through
brick walls, or has to be hidden in a wall cavity, be routed through
the ceiling/floor for appearance etc.
Also depends on the condition of the fuse-board too. if its something
40 years old thats already overloaded to buggery, then a sparky might
insist on it being upgraded in order to be able to connect another
socket.
Of course, the cheapest way would be to get a socket mounted on or
next to the actual board, and run a 15a extension cord. To do this is
extremely easy if you have a modern DIN rail board and use a DIN rail
power socket.
As a guesstimate for a non-complicated cable run - about $200.
As others have said, while you have the sparky there, If there are
other projects you have been putting off, it would be a good idea to
get them done as well - while he is there.
Finally, a word of warning. A mate of mine who bought a 1950's home
about a decade back, had a nasty electrical fire start at the rooftop
cable entry box (where the cable from the street pole joins to the
house). Turned out that when the house was built, they only used 6mm
sq cable for the main to the fusebox and after adding an air-con unit,
electric stove (originally had gas) the load proved to be too much for
the cable and it had to be replaced. I would insist that the sparky
check that your cable is a sufficient diameter while he is there. In
this case they upgraded the cable to 16mm sq.
atec77
efficiency??
MrT.
Once again I say you sir really know sfa about the inner workings of a
computer , google surge and Ohms law .
N
Nick Adams
Tacked to wood bearers. It's under the house and fully accessible to
walk around. The cable can run through the existing hole in the wall to
the board.
socket.
Probably less than 20 years or so. Looks "recent" enough considering the
few fuse boards I have seen.
power socket.
That would work. Interesting...
Seems to be the general consensus.
We will definitely need a RCD device so there's something.
Will do. Many thanks to everyone for their advice.
Mr.T
What exactly should I be looking for? If Intel says a Pentium draws 135W at
full load, (Ok the new ones are only 95W) how do I power it from a 100W
power supply? Where does the power come from for the rest of the computer?
What is the efficiency of the PSU?
Please provide all the Ohms law calculations you believe are appropriate.
MrT.
atec77
MrT.
Do you own work sport , it will be far more worthwhile.
however keep in mind the power supply is work case max , it takes more
to spin a drive up than to keep it spinning .(generalized example and
have fun)
Mr.T
In other words you have no idea what you are talking about. If you used
Google yourself, you could find out just how uninformed you actually are.
have fun)
And hard drives are the least of your problems unless you have a few. Even
some video cards draw more than 100 Watt these days. The heatsinks and fans
aren't just for show!
But you may still be running an 8086 with CGA and floppy disk drive I guess
MrT.
