creating a 9VDC rechargable battery backup for an alarm clock radio
In my community, we have interruptions of electricity more than
average. My alarm clock has one of those 9v battery backups, but one 4
hour blackout can significantly drain the battery, requiring me to
check and frequently change it. One solution would be to connect my
alarm clock to an uninterruptable power supply.
But I would need atleast a 500VA, they can be expensive and many of
them beep when running on battery power.
I was wondering if I could just wire in a 9v rechargable NIMH battery
(8.4v) and connect the output of a cheap 9v-style battery charger to
this battery
(such as
http://store.yahoo.com/minilab-supply-store/raynimchar9v.html )
Do any of you know what I could expect as far as voltage from the
charger across an 8.4v NIMH battery while its charging? As long as the
voltage remains below 10v, the clock should tollerate it well. Thanks
V
Vidar Løkken
You can add a diode (a germanium only lowers voltage by 0.2-0.3V), thus
stopping current from the charger to the clock, when charging. Add a
diode pointing towards the clock connection from the + of the battery. I
can draw you a quick schema if you want :)
In said:
One solution would be to connect my alarm clock to an uninterruptable
power supply. But I would need atleast a 500VA, they can be expensive
and many of them beep when running on battery power.
I would really like to see the "alarm clock" that needs a 500 VA UPS
to keep it alive. I would think that one of those ~150 VA "fat power
strip" UPSs would keep your alarm clock humming. (But it might be
interesting if your clock uses the line frequency for timekeeping and
the UPS isn't at exactly 60.0 or 50.0 Hz...) Plus, if you are
reasonably careful, it's not too hard to cut the trace to the beeper,
or remove it altogether.
Matt Roberds
CWatters
500VA ! Must be a really big alarm clock.
this battery
(such as
If you plan on leaving the charger connected permanantly you should check
what the float current is into the fully charged battery. Otherwise you can
kill the battery - sometimes quite quickly. Ideally you need just enough
current to match the self discharge...
http://store1.yimg.com/I/starbattery_1838_658029
mike
this battery
(such as
Use some voltage from inside the radio to do the charging.
FWIW, I've never had a 9V rechargeable battery last. They're tiny cells
and seem to short out faster than I can use 'em up. I'd go with bigger,
more reliable cells.
Might be better off with a new alarm clock that's always battery powered.
mike
ps 500VA???? That's gotta be some LOUD alarm.
Return address is VALID but some sites block emails
with links. Delete this sig when replying.
Wanted, PCMCIA SCSI Card for HP m820 CDRW.
FS 500MHz Tek DSOscilloscope TDS540 Make Offer
Wanted, 12.1" LCD for Gateway Solo 5300. Samsung LT121SU-121
Wanted 13" LCD for Mitac 6133 Samsung HT13X13-201
Bunch of stuff For Sale and Wanted at the link below.
MAKE THE OBVIOUS CHANGES TO THE LINK
ht<removethis>tp://www.geocities.com/SiliconValley/Monitor/4710/
John Woodgate
OTOH, I have a few that have survived for 14 years and still have usable
capacity. But then this year is Y MMV!
H
H. Dziardziel
this battery
(such as
Have you considered just a couple of AA cell holders and use AA
alkalines? Branded AAs have excellent shelf lives and 100 times
the mAh capacity of 9V batteries so will probably last for years
in that application. Total physical size<wallwart size with
about identical cost..
what kind of alarm clock drains a battery in 4 hours? Big Ben? If this
is true, there is something seriously wrong with your alarm clock! Get
another.
theres definately something youre not telling us! :)
NT
