Cross
AN920
May 15, 2005
359
Will the phase shift always be the same or variable?
m-a-r-i-n
Sep 21, 2004
35
Phase is variable,amplitude is constant. Circuit need detect cross two sine wave and
show that value of voltage.
AN920
May 15, 2005
359
Are the waves separate like on 2 inputs or combined at some point?
saiello
Dec 7, 2006
21
Couldn't you use a comparator that takes both inputs. When the output is zero, the signals are at the same voltage, i.e. 'crossed', then all you have to do is to take a reading from one of the inputs for the actual value.
aniruddha
Dec 17, 2006
123
Hi m-a-r-i-n,
I agree with zeppelin, why so complicated. ???
As far as the working is concerned, in the top line, 1st comparator is used to detect the crossing, the schmitt is to eliminate noise-chatter, 2nd comparator acts as a plain inverter to nagate the effect of "inverting scmitt trigger", and the 3rd comparator is just a vtg. follower acting as a buffer. Atleast thats what i've analysed ;)
But the whats the purpose of that 4th comparator sitting at the bottom???
I think its quite unnecessary and makes the circuit complicated.
But surely u must have had some reason to use it. Care2justify? :-\
m-a-r-i-n
Sep 21, 2004
35
Well this is how i create the circuit in blocks....comparator compare two sin wave voltage, when output is 0, the comparator activate digital circuit to activate pump capacitor on the level of voltage from one voltage
sources. Then the output is equal cross voltage....this is short explanation
