crt tv horizontal display problem
walid ahmed
Aug 12, 2017
9
The crt tv cant display horizontally. The HOT and yoke coils are ok.....when horizontal yoke coil connected then the tv dont turn on...when removed then it ONs.
14,471
things like the make and model of TV would be really helpful if you want some one to help you
have you googled for service manual or at least a schematic ?
walid ahmed
Aug 12, 2017
9
i replaced with best HOT. and driver transistor also...but when horizontal yoke connected only then tv didnt turn on
walid ahmed
Aug 12, 2017
9
so the tv model will not do to identify the present pcb connected
kellys_eye
Jun 25, 2010
6,512
Without a schematic to reference to what do you expect us to advise? Or should we just guess? I can't find any reference to match the details you have already given. Unless you can show us a picture of the board or the diagram we're pretty much in the dark.
Have you checked the sync pulses to the board?
debe
Oct 15, 2011
278
I guess if you are using a PCB that wasn't meant for that deflection yoke then theres a mismatch, & it wont work
14,471
thread closed
@walid ahmed when you are able to supply make and model of the TV you are working on
PM me and I will reopen the thread
There is no point in all of us playing 20 questions if you are not going to supply the needed info
walid ahmed
Aug 12, 2017
9
Ok dear...i failed to give u any info about the tv....close the thread and just tell if the horz shorted yoke can prevent the tv to turn on?
kellys_eye
Jun 25, 2010
6,512
If the horizontal yoke is shorted it will cause an overload of the power supply and shut the set down.
shrtrnd
Jan 15, 2010
3,901
If the filament at the neck of the picture tube lights-up, the picture tube is on.
The yoke is a separate circuit.
73's de Edd
Aug 21, 2015
3,730
Sir walid ahmed . . . . .
You say . . .
This pic below is showing a problem with the sets HORIZONTAL CIRCUITRY or the yoke
A quite rarely occurring condition . . . . .
If you have the MUCH MORE COMMON problem, where the bright white line will be ACROSS the screen from left to right, instead of UP and DOWN, as is shown in my 1st picture.
THAT will be a VERTICAL problem.
Now which is it.?
Also, does the sound always remain on ?
You say . . .
Are the hoz and yoke connections being SEPARATE . . . . two pin . . . . plug in connectors ?.
73's de Edd
