CTEK MXS 3.8 repair
73's de Edd
Aug 21, 2015
3,730
Sir bushtech . . . . .
A query . . . back to the controller IC . . . . . . . is that 8 pin unit missing its pin 7 ?
Confirming, with that forthcoming info . . . . . see if that likely NCP1271 controllers output pin # 5 either goes to the shared bases of a tandem pair set of complementary transistor drivers, being arranged as a rail to rail totem pole driver, of which , they then have their shared central collector-emitter junction feeding into the gate of the pooooopped power FET.
Its popping should have introduced a high voltage into those driver transistors, of which, you have already explored the PNP counterpart, but now need to seek out the nearby NPN companion, to ascertain its condition.
I will now be looking at the Mantech site, to see if they have any Infineon N channel 600V rated, logic level drive Power FETS that could sub in for what you currently have.
73's de Edd
Education is . . . Learning what you didn't even know that you didn't know.
bushtech
Sep 13, 2016
1,025
Wowee! St Edd. Right on the money as always.
Pin 7 of the NCP1271 is indeed missing.
There is a complimentary set of transistors, 2fe and a6w. Pin 5 is connected to the connected bases of these two.
The gate of the mosfet is connected to the emitter of the 2FE. From emitter of the 2FE the connection runs through a 22 resistor to the common of the a6w.
Thank you thank you
bushtech
Sep 13, 2016
1,025
When I search for that A6W transistor I get to a MMBTA05 Gen Purpose NPN transistor. Is this it?
bushtech
Sep 13, 2016
1,025
@73's de Edd
St. Edd, hopefully this helps. Attached is a LTSpice file showing the circuit from power in through rectifiers and mosfet and to the 2 tandem transistors and their connection to NCP1271.
Please excuse any errors as I battle with LTSpice and it's tricky plotting an unnumbered pcb. Diodes could be pointing the wrong way etc. Please ignore the two unattached inductors on the right. I am trying draw the transformer with it's 4 primaries and 5 secondaries.
  • Ctek 3.8.asc
bushtech
Sep 13, 2016
1,025
Bit of an oddball question: I pulled the 04N60C3 mosfet and then powered up to check some voltages. Instantly blew fuse on power up. On checking I notice a dead short between the drain and source holes on pcb. Is this how it's meant to be or have I got a short somewhere else?
bushtech
Sep 13, 2016
1,025
Sorted this particular problem. 3 of the 4 rectifier diodes blown.
bushtech
Sep 13, 2016
1,025
I want to replace the two tandem transistors marked 2FE and A6W. On closer inspection of my photo in post #44 the 2FE could actually be a 2F.
Searching for this transistor brought up this: https://www.google.com/url?sa=t&rct...MBT2907A.pdf&usg=AOvVaw0h21C5BkliR-WwIFQC51Pn
This could be correct but could somebody please confirm.
The A6W is a bit more tricky. Downloaded all the smd code lists in our resources section and some others. Various components come up but I have no way of saying which one is correct. Can somebody please help me to find the correct replacement transistor.
73's de Edd
Aug 21, 2015
3,730
If me, I would be using leaded transistors and a 2N2907 would be the PNP amd a 2N2222 for the NPN since they are siamese twins on their specs.
I would be shortening the stock leads just enough so that you would be able to swing their CBE leads around into PROPER pin alignment ( TRIPLE CHECK ! ) to their perspective pads, yet with them still being long enough to be able to result in a NEAT installation.
Be sure to pre tin the leads, so that they will then just rapidly melt into place on the solder reflow of their installation.
I was unable to get back in time for the full wave bridge diode conundrum, with its 4 discrete surface mounts (1N4007 equivalents) and was certainly just expecting 1 or more dead shorted diodes, as your problem.
The thing about this design, in its using an appropriately selected value of series capacitor to reduce line voltage on down to create a low voltage supply, is that it folds up on its power output, if being overloaded from the norm.
ERGO . . . with your controller IC receiving some degree of isolation by the totem driver transistors and the power supply folding back, we might now take a feeling for the pulsebeat of the controller IC .
Do you have a small pocket shirt size AM radio receiver ?
73's de Edd
People can be divided into three groups:
Those who make things happen, those who watch things happen, and those who wonder WHAT the hell just happened ? ? ?
bushtech
Sep 13, 2016
1,025
Thanks a mill St Edd
Pocket sized? No, not for many years;)
But I have this:
Hope this can work.
bushtech
Sep 13, 2016
1,025
St Edd, I am quite happy soldering smd components on. Is there a specific reason for going with leaded components? If something like higher reliability, etc then I will go with leaded components but if not I would prefer to go with smd components
73's de Edd
Aug 21, 2015
3,730
OK then . . . . I was just thinking back to one of your pics of one unit of a set of 2 wireless switch boards of yours, a couple of years back . . . . . maybe muuuuuuuch practice / experience and a small tipped soldering iron, has now imparted a threshold of quasi perfection.
The 2907 and 2222 are available as surface mount parts.
73's de Edd
I prefer going to Dollar General, as you do not have to dress up for Dollar General like you do if you go to Wal Mart.
bushtech
Sep 13, 2016
1,025
Me and my soldering iron have walked a long road since then.
How about the AM radio?
bushtech
Sep 13, 2016
1,025
St Edd
I found another forum post where you describe the usage of the AM Radio and tried it. Couldn't hear anything above the crackling of the AM radio no matter how I rotated it.
I had previously measured voltages on the NCP1271
FB pin 2 = 3.6V
Vcc pin 6 = 9V
HV pin8 = 328V
No reading on the other pins (which I suppose is logical)
I decided to recheck those readings and while I was reading pin 8 a 1.5kΩ resistor decided to fry itself and depart for the happy hunting ground. No idea why this happened, pin 8 is conveniently freestanding with no pin 7, so short caused by probe unlikely. Ground used for measurement was neg of big cap.
It's the 152 resistor shown by the left most arrow.
I must also add that the NCP 1271 was running pretty hot when switched on through dim bulb tester
bushtech
Sep 13, 2016
1,025
I replaced the 04N60C3 fet and the blown 1.5k resistor.
Readings I'm getting now: (All relative to neg of big cap)
Voltage on big cap: 336V DC
04N60C3: g: 0V
d: Jumping around in the 200, 300V DC
s: 0V
NCP1271 (7 leg chip)
1 0V
2 0V
3 0V
4 0V
5 0V
6 14V Vcc
8 334V HV
Are there any other readings I can take which might lead us to the problem
I have got replacements for the NCP1271 chip and the 2 complementary transistors, 2N2907 and 2N2222
73's de Edd
Aug 21, 2015
3,730
This design ap note might help a bit in seeing how they were thinking and the units circuitry .
I found no related 1.5 k . . .and that would tend to have some of that 300 vdc tied into it to be able to fry it.
And none of the lower voltage 18VDC from its zener and the supply line for the 1271
proper, could inflict that power level to that value of resistor.
Your circuitry also has the additional totem pole transistor drivers as I have shown in the RED inset.
Is that being the original 1271 that is still installed ?
At least you now have a good power fet installed . . . but apparently it is not receiving any 1271 drive.
Do we have any small value resistors tied into the input-output or CBE's of the driver transistors ?
SCHEMA REFERENCING . . . .
73's de Edd . . . . .
Statistically . . . . . it has been found that 6 out of 7 dwarves are not Happy.
bushtech
Sep 13, 2016
1,025
Thanks St. Edd
Yes, it is still the original 1271.
I am trying to find correlation between your application note and my board's reality.
Three posts up is a photo with a red arrow pointing to the blown resistor. Now, is that a 152 resistor or a 251 resistor? If I measure the unblown identical resistor next to it it measures 1.5K
bushtech
Sep 13, 2016
1,025
@73's de Edd
I have attached a portion of my LTSpice file showing relation between NCP1271 and the 2 driver transistors. No guarantees that is correct. Helluva job creating the LTSpice simulation for the CTEK
  • ctek Part 1.asc
bushtech
Sep 13, 2016
1,025
I have nearly finished the LTSpice simulation. Still some components at the top of the board to do. So I decided to start taking some voltages on the board.
Voltages are shown in dotted rectangles.As can be seen on the simulation voltage on big C5 cap fine (331V) But when I go to the next component in line R4 (0.47Ω) I get no voltage. Although the same voltage arrives at the transformer as can be seen.
I don't understand this, am I missing something.
Please help
  • Ctek 3.8.asc
