panfilero
- Jan 1, 1970
- 0
Hello, I need to design a current amplifier. I'm trying to design a
virtual instrument in LabVIEW to which I can type in a current (for
example 1.5 Amps) and then have that current realized at the output of
a current amplifier. I believe LabVIEW will provide a small voltage
which I can feed into the current amplifier and then use the output of
that.
I'm going to be using this to drive a real small load of only 15 Ohms.
and would like to be able to push 2 Amps through it (this would be my
maximum current). I think I will be driving the amplifier wtih
millivolts from that DAQ. So I guess this would be the same as having
a 30 Volt output?
This is the first time I've ever attempted to design an amlifier and
was wondering if anyone could give me a little guidance or point me in
the right direction. I think what I'm trying to make is a: voltage
controlled current amplifier. I was wondering
1) Where should I be looking for something like this, at Op-Amps,
FETs, BJTs?
2) Whats the difference between a current amplifier and a voltage
amplifier, in this case it seems like you could describe this as
either.
appreciate any help i could get with this
thanks
joshua
that.
a 30 Volt output?
FETs, BJTs?
either.
thanks
joshua
