using bjt amplifier to obtain a current higher than the maximum current an arduino can output
abder
Dec 12, 2021
3
I need to output a current of 0.16 A from an Arduino uno , but the maximum current the Arduino can output is 0.06 A so I thought about outputting a certain voltage then using a bjt amplifier to amplify it and then add an output resistance to control the current flowing through the output, I did all the calculations as shown in the image :
the voltage gain of the bjt is : A = 300/100 = 3 so if I output 2.5V from the Arduino I should obtain Vo = 7.5V.
, but when I simulate the circuit, (I checked all the connections they are correct and I indeed have 2.5V in the arduino output) I get Vo = 2V instead of 7.5V I thought about this a lot but I can't seem to find where the problem lies so If someone could help me out with this I would appreciate it a lot!
bertus
3,882
Move the resistor from the emittor to the base.
Bertus
abder
Dec 12, 2021
3
hello,
thank you for your answer, I get now Vo = 0 volts :(
bertus
3,882
I mean as series resistor between the arduino output and the base of the transistor.
Bertus
abder
Dec 12, 2021
3
I did this as well but when I stimulate this I get no current flowing through the collector as shown in the image
Audioguru
Sep 24, 2016
3,656
Your original circuit has a voltage divider all the time.
WHONOES
May 20, 2017
1,242
Are you trying to supply 160mA into your load at a terminal voltage of 7.5V or is it meant to be a constant current and that the 7.5V is just a result of that specific current flowing in your load?
Audioguru
Sep 24, 2016
3,656
Simple Ohms law says that for 7.5V into the 46 ohms load then its current is 7.5/46= 163mA. The 163mA in the 300 ohm resistor needs 163mA x 300= 48 9V. Then the supply voltage must be 7.5V + 48.9V= 56.4V plus the 1.8V at the emitter of the transistor = 58.2V.
Without the load but with a 9V supply then with a 2.5V input, the emitter will be 2.5V - 0.7V= 1.8V and the emitter current will be 18mA which will also be in the 300 ohms resistor which will have 18mA x 300= 5.4V across it. The total is 1.8V + 5.4V= 7.2V so the 9V is too high.
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
Bye, bye, @abder!
It appears you are one of our infamous drive-by posters who leaves when an immediate answer to their problem is not forthcoming. I say this because you have not responded to a dialog offered by @WHONOES and @Audioguru. Perhaps you were put off by @Harald Kapp's suggestion in his post #7. Perhaps @bertus' two attempts to help you convinced you that this was not the right place for you. Or, perhaps, the brown-black-white (10,000,000,000 Ω) gold (5% tolerance) resistor shown in the collector of your transistor in your post #5 limits the current to a value too small to show in your "alleged" simulation?
Yep, a 10 GΩ resistor will definitely "simulate" virtually zero current. A real 10 GΩ resistor is likely to be a glass-encapsulated rarity that you will probably never encounter. The glass is there to prevent a shunt path around the resistor. Such resistors require special techniques when inserted in a real circuit to avoid "shorting out" their extremely large resistance values. This is a major problem working with simulations instead of real components: how do you know the simulation is representative of the "real world" unless you build with real components? BTW, 10 GΩ resistors may also be used in high-voltage applications, upwards of a megavolt or so, but they are large and often surrounded by SF6 insulating gas at a hundred or more atmospheres of pressure... again, not something the average electronics enthusiast is likely to encounter.
