Current Flow
Zalves
Jul 26, 2023
Hello everyone!
I just started to play with electronics, a kids dream that I've finally set to explore.
I have created a circuit with a couple of LEDs a transistor and a switch as a learning experiment. I'm very confused on how the current flows, I'm adding an image to illustrate. On the left I can't understand why the current stops flowing to the left LED.
Very confused...
bertus
3,882
The led will have a voltage drop of 1.5 Volts to 3.8 Volts depending on the color.
The B-E voltage of a silicium transistor will be about 0.7 Volts, so the led will go off, as there is not enough voltage drop.
Bertus
danadak
Feb 19, 2021
1,104
The graph shows you what the Vbe of a NPN does as is base current turns it on. As you
can see it does not change much once it gets > than its intrinisc threshold. So as previously
stated by bertus an LED in parallel with that junction simply wont conduct.
Regards, Dana.
AnalogKid
Jun 10, 2015
3,058
Put another way, the LED *requires* a forward voltage across it of greater than 1.5 v to 3.8 V before it will emit light. The forward voltage of the transistor's base-emitter junction clamps the voltage across the LED to only 0.5 V to 0.8 V for a typical small-signal transistor. Thus, the transistor is "on" and the left LED (reference designators!) is off.
ak
Delta Prime
Jul 29, 2020
2,996
There aren't any, making a detailed discussion of the circuit fraught with ambiguity and peril
Duh! I was just taking the heat for the TS.
I like your style!
But I always have to remind myself this site is akin to a hospital pediatric emergency room. I feel bad saying that because I lost it as well in my most recent response to posts.It can be rather....
o_O
AnalogKid
Jun 10, 2015
3,058
Rule #1 in forums - First, answer the question that was asked.
Rule #2 - Bang on and on about reference designators and which way ground symbols point.
ak
Zalves
Jul 26, 2023
ak
Thanks, make more sense. For what I understood, the base of the transistor makes that part of the circuit only have 0.7V
crutschow
May 7, 2021
991
Yes, when the transistor is on, the base-emitter voltage of a silicon transistor is about 0.7V.
Since the LED requires more voltage than that to turn on, it will not conduct any current and will look like an open circuit.
bidrohini
Feb 1, 2023
221
I can see that you've already got your answer. For more details about how transistors work, you can see here:
