DAC vs digital potentiometer
Cirkit
Oct 28, 2015
156
What is the advantage of using a DAC over a digital potentiometer?
If the digital potentiometer is supplied from a stable regulated supply, is it not serving the same purpose as a DAC?
I understand that a DAC may be faster however, for applications where a fixed voltage is set at power on would a digital potentiometer be adequate?
14,311
A digital potentiometer is uses, as the name says, as a potentiometer to attenuate a signal. The number of steps is usually limited, e.g. 128 or 256 steps (examples). Alos available with logarithmic characteristic for audio applications (e.g. digital volume control).
A DAC on the other hand is used to convert a digital signal into an analog representation of the digital signal. Resolution is often 10, 12, 14 or 16 bits or even more. Much higher than a typical digital pot. Also usually linear (although variants with non-linear characteristics also exist). DACs are typically used to generate a signal, not to attenuate a signal (although multiplying DACs can be used for the latter purpose, too).
If the resolution and accuracy of the digital pot are good enough for the application: yes.
dragon
Oct 31, 2022
248
Why do you need digital values when analogue ones work so good already!
I think its a problem with the industry these days.
Cirkit
Oct 28, 2015
156
I want the ability to set the same value at power on or be able to adjust it in software. I did think about using a standard analogue potentiometer however, this may drift and requires careful manual adjustment.
dragon
Oct 31, 2022
248
Maybe they are a bit fiddly. but pots dont drift thats only analogue delay lines that do that for example. (each time they feed-back.)
-edit- software adjusted pots would be pretty spiffy. -edit-
crutschow
May 7, 2021
991
So what resolution/accuracy do you need for that adjustment.
That may well determine whether to use a digital pot or a multiplying DAC.
What signal frequencies are involved?
