daikin fwc07b7fv1b current
Integrator741
Jun 16, 2013
125
Hi all,
I am trying to calculate maximum current drawn by daikin air conditioning unit.
On technical sheet it says maximum power is 6.6 kw.
So if I operate the unit at maximum power I draw 6.6/240 amps, don't I?
Now the unit is supplied by 1.5mm flex, which has current carrying capacity of 16 amps.
When I turn the unit on, it's working fine, but something is wrong with speed, because no matter what speed setting I press, the unit doesn't react. So I was thinking could it be the 1.5mm flex that's not giving enough current? Or something wrong with controls?
Thanks.
14,317
6.6 kW / 240 V = 6600 W / 240 V = 27,5 A. No way to operate this unit on a 16 A fuse. Is this a single phase air conditioner or a three phase air conditioner? A three phase unit in delta connection will see sqrt(3)*240 V = 415 V per leg, thus current is 6600 W / 415 V = 16 A which is imho more plausible.
Is 1.5mm the diameter, radius or cross sectional area? Note that it is common to label a conductor according to the cross sectional area.
Assuming 1.5 mm is the diameter, this calculator gives a resistance of approx. 0.01 Ω per meter. Double that for a 2-wire cable to get 0.02 Ω per meter. At 25 A (assuming it is a single phase system) thsi is equivalent to 0.5 V voltage drop across each meter of cable or equivalently 0.2 % per meter of cable.
I doubt this voltage drop will influence the operation of the air conditioner. You will see a much higher change in voltage from voltage fluctuations typical for mains.
It is very probably the controller that is not doing its job.
Integrator741
Jun 16, 2013
125
It's a single phase. 1.5 mm diameter. Distance is not big either.... also it's fed from 13 amp spur, so I think it would have blown the fuse if it was taking that much current. But what can possibly be wrong with controller? All the other functions are fine.
