Danger of running hot receiver (Kyocera)?
David Nebenzahl
Got someone with a Kyocera receiver (R-851, 85 w/chan.) that they say
"smells like something's burning". Don't have more specific information
than that; I'm assuming no magic smoke is visible. I'm advising them
that perhaps something (dust, etc.) is in the heat sink that's getting
heated and smelling. Apparently the output stages (MOSFET) of these
beasts tend to run on the hot side.
Question: does anyone know what kind of overcurrent or overtemperature
protection this unit has? User is concerned about "ruining" it if it is
in fact overheating (which I can't determine at this distance). They're
running it with 4-ohm speakers at not-very-high levels; I also suggested
trying it with 8-ohm speakers and seeing if the smell lessens.
Not much info to go on, I know, but I really would like to know more
about any protection circuitry in this piece of gear.
Meat Plow
If it smells of burning electronics I would strongly suggests the person
unplug the unit and get it somewhere to be looked at. Smoking the outputs
in a DC coupled amp can cascade back through driver and current control
stages in the blink of an eye and cause a catastrophic amount of damage.
W
William Sommerwerck
My gut feeling is that the owner is simply smelling "burning dust". But he
should stop using it immediately, and have someone look it over. It might
need only a thorough vacuuming.
David Nebenzahl
A bit of a reach... A 35 degree rise above ambient in a room at 68 F
feels warm to the touch, but when you run the same amp in a hot
location, room temp 90F that absolute temperature is now 125F and you
feel burnt touching it. Just like its summer here the room temp there
could be high, perhaps there is something overheating and outgassing,
for a while.
That's along the lines of what I was thinking too.
I used to use this receiver, which ran fine for years with no noticeable
odors whatsoever. It *is* incredibly overbuilt, as someone else
mentioned here, so I'm not particularly worried about an impending
catastrophic failure.
Still would be nice to find out specifically what kinds of protection
circuits it has from someone who actually knows ...
Cydrome Leader
weird heatsink in that thing:
http://www.audiokarma.org/forums/showthread.php?t=246095
Chuck
This unit doesn't have thermal protection but it has a DC offset
protection. This model was extremely reliable but I repaired one that
had both amplifiers completely wiped out. Even though I told the
customer I wouldn't void his warranty if he told me how he managed to
accomplish this feat, he wouldn't divulge what he did.
W
William Sommerwerck
Plugged the speaker outputs into an AC wall socket?
I had an amplifier with DC offset protection, in which the amplifier failed,
and the protection failed, at the same time, an incredibly unlikely
coincidence. The DC damaged one of my speakers.
Cydrome Leader
Meat Plow said:
I've seen many of those in different pro power amps.
It's a first for me. I can't say I've ever seen a kyocera amp in the US
either.
Do those heatpipes ever leak or break after being decades old?
Meat Plow
either.
Yep they sure do. I worked for a warranty station that did a ton of
Matsushita enterprise offshoots and saw the heat pipe mainly in condensed
units (consumer grade) so they really didn't have to design the rest of
the thing around the amplifier. They could put the final section where
they wanted it with minimal heat sinking and run a tube bent to fit
wherever there was enough space for some finning. Don't ask me what goes
on the inside of the pipe I suppose it depends on the designer. But I
have received tech bullets and shipment of replacements just in case we
got a run of units that had defective pipes. Having replaced a few I
can't recall seeing anything that 'leaked' out so again I have no idea
what was inside but it probably was an inert gas, I doubt if it had any
of the properties of a freon refrigerant. Maybe someone could expound who
actually knows for certain. I have one old SCS (Sound Code Systems) MOSFET
pro power amp that uses a finned heat pipe with the MOSFETS mounted on
the end. This amp has got to be 3o years old, uses the Hitachi K135/J40
FETS long discontinued. It's 350 per side into 4 ohm. Used it for a few
years as part of my bass guitar rig until I came across a non-working
Crown Mico-Tech 1000. It needed a diode block bridge and has worked
flawlessly since 1993.
Chuck
either.
Kyocera was sold by high end audio salons in the U.S., during the mid
80s, as an entry level line. The products were very well built and
reliable. One of their cd players was sold under the ADC brand name
at a very low price. It was probably the best cd player buy in its
day. Chuck
Trevor Wilson
Cydrome Leader said:
**Ah, heat pipes. Quite common in the late 1970s, early 1980s. If the fluid
has leaked, there can be problems. A quick way to test is to power up and
ensure that heat travels rapidly (less than 10 seconds) from the hot devices
to the other end of the heat pipe. If it doesn't then it is possible that
the fluid is gone from inside the pipe.
David Nebenzahl
Having been inside this unit before, I'm fairly certain the heat pipe is
intact.
Any idea what the fluid is?
Trevor Wilson
intact.
**You need to measure to be certain.
**Not really. Some kind of refrigerant. It could be FreonT, ammonia, alcohol
or a number of others.
Cydrome Leader
I got curious and dug up a sample of a heat pipe (Noren Products
http://www.norenproducts.com ) from a trade show, and it seems they can
even be filled with distilled water depending on the use.
It's still interesting to me that anybody bothered to use these in
amplifiers, products where nobody cares about size and complains about it
being made too sturdy and too heavy.
I have an ATI amp where it's not clear if the heatsinks or tranformer
weigh more.
Meat Plow
it being made too sturdy and too heavy.
weigh more.
The whole heatpipe/heat sink/mosfet mount block assembly on my SCS
350x350 WRMS rackmount amp probably weighs 2 pounds minus the 12 fets.
The actual heat sink looks like a round bristled aluminum brush through
which an infinitely speed controlled fan blows through from back to
front. SCS is not in business now, hasn't been for a long time but I
really like this amp. Low THD for a pro audio amp easily usable for a big
home system. Makes no noise unless you're pushing it then the noise
doesn't really matter.
