Darkroom timer V2.0A project question ????? (Solved)
guizmo
Dec 27, 2009
5
Hi, this is my very first post on this forum, so I hope someone will kindly answer my question.
I'm building the Darkroom timer found on this site. I have made the circuit on my breadboard and everything works very well. So I'm making the first part, the display unit. Just for your information I make my own PCB.
That's where my problem is !!!! I'm loosing my mind here ....
Let say I have the number zero displayed on all 4 LEDS, the letter D, E don't light up on LED 1 but the other 3 LEDS are ok ???? Sometime letter C of LED 1 2 3 is barely visible but LED 4 is ok ???? That goes for other numbers too !!!!
And before you ask, none of the 7-segment of the LEDS are burned because I can switch the LED is any position, they are mounted on 20 pins dip socket that I cut.
Thanks for your answers.
guizmo
Dec 27, 2009
5
Problem solved, I made sure that they were no more flux between pads !!!!!
Did not know that flux could do that but anyway that's the only thing I did and it is working well now !!!! Go figure it out ??? .........
KMoffett1
Nov 27, 2008
65
Flux , except in extremely high impedance circuits like pH meter inputs, should not cause a problem.  Years ago I read in an H-P service bulletin concerning field repairs to PCBs, that unless "all" flux can be removed (think in-factory process) it should be left in place.
Ken
Hero999
Oct 28, 2007
2,433
I generally try to remove as much flux as possible because it looks better and I've heard stories about it attacking copper in moist environments.
