Darlington TR
shahzad-h
Mar 27, 2006
42
HI audioguru
Thanks for ur fast reply
Ok Before biasing darlington I biased ordinary transistor 2N3904
shahzad-h
Mar 27, 2006
42
HI audioguru
I don't know how to attach the ckt ??? there fore i m giving u assumptions that i made FOR
audioguru2
Apr 6, 2004
12,026
Hi Shahzad,
Look at the datasheet for the 2N3904 to see its typical spec's with 1mA collector current.
1) HFE= 230.
2) Vbe= 0.68V. Yours is much too low.
Your 900 and 85k resistors aren't standard values.
The current in R1 and R2 should be about 10 times the transistor's base current.
Recalculate the R1 and R2 voltage divider for the proper amount of base voltage and your circuit will be fine. You can download a simulation program to test it if you want.
When you post a reply, click on Additional Options then click on Browse and double click on the file on your pc of your sketched schematic that you want to attach.
shahzad-h
Mar 27, 2006
42
HI audioguru
I rebiased the ckt with HFE=230 it works perfectly ;D ;D i checked in circuitmaker software
audioguru2
Apr 6, 2004
12,026
shahzad-h said:
it amplifies 5mv 1Khz signal to 500mv
Without having about a 10uF capacitor as a bypass across the 1k emitter resistor, the voltage gain is only about 3.6. With the bypass capacitor, the output is very distorted at high levels.
Sorry, I can't upload a pic of the distortion.
In ur FM transmmiter
audioguru2
Apr 6, 2004
12,026
Here is a pic of transistor distortion without having negative feedback from an unbypassed emitter resistor:
EDIT: Nope. I am not allowed to upload any more because my upload folder is full!
audioguru2
Apr 6, 2004
12,026
Let me try again to upload a pic of transistor distortion:
EDIT: Nope, my upload folder is still full so I can't attach anything.
audioguru2
Apr 6, 2004
12,026
Your input and ouput levels are very low. Turn them up and you will see gross distortion because your trsnsitor doesn't have any negative feedback:
audioguru2
Apr 6, 2004
12,026
Look at crossover distortion in Google.
Your single transistor cannot produce crossover distortion.
Crossover distortion is caused by two transistors as emitter-followers in the output of a power amplifier and without enough bias current so they operate in class-B. The distortion occurs when the signal crosses over from one transistor to the other transistor but they don't have bias current to function smoothly.
shahzad-h
Mar 27, 2006
42
Hi audioguru
sorry I worngly write cross instead of gross i reduced the gross over distortion by introducing negative feedback I replace the 100uF bypass capacitor with 1.5uF and  I m attaching Two images first with distortion and second with reduced distortion and show me how much distortion is generating now
audioguru2
Apr 6, 2004
12,026
You reduced the value of your bypass capacitor (for the emitter resistor?). Therefore you introduced negative feedback only at low frequencies. Your harmonics pic shows that distortion for higher frequencies remains the same as with a much larger bypass capacitor.
An unbypassed emitter resistor introduces negative feedback for all frequencies and total distortion is reduced.
I cannot see how much distortion your circuit has without seeing its fundamental frequency's output level and seeing all harmonics. Harmonic distortion is all harmonics added together as a percentage of the output level.
audioguru2
Apr 6, 2004
12,026
Your sim shows the same 1kHz frequency as before, but the phase-shift is different. Your sim is not done properly.
shahzad-h
Mar 27, 2006
42
HI audioguru
can u plz make my ckt in ur sim the values are
Rc=3.6K,RE=1K,R1=90k,R2=24k
C1,C2=10uF
