Datasheet for Zilog Z8047BB1 DART
bonzer
Can anyone point me in the right direction to get info on this IC?
Matthew
Remove _ for valid address
Matthew
I have the databook (Mostek 1984/1985) containing the Z80 SIO
(aka MK3884/3885/3887 - there are 3 slightly different pinouts as
there were 41 signals to fit into a 40-pin package). If you can't
find it on the web somewhere then I could be persuaded to scan it
for you (15 pages). I worked with this chip a long time ago, and
I think there was a bigger book too devoted to the SIO with more
details of function of every register bit, though the spec I have
here is probably adequate (especially for async only).
The Z80 DART (Dual Async Receiver/Transmitter) was a version of the
Z80 SIO (Serial IO) chip. It appeared to be how they labelled ones
where the synchronous features didn't work (so they could sell off
some of the parts that failed test as SIOs).
Mike.
bonzer
Hi Mike,
Thanks for the reply. I already have a datasheet for the Z80 SIO 8440.
Would that be a similar match for the DART or would your datasheet be
nearer the mark?
Thanks again,
Matthew
Hi Mike,
nearer the mark?
I don't have the mapping from Zilog numbers to Mostek ones, so 8440
means little to me, however I believe that if you already have the SIO
datasheet then you effectively have the DART datasheet. As far as I
recall, the DART datasheet (a single page?) just said something like
"The DART is a reduced function version of the SIO in which only async
modes are supported."
Does your SIO datasheet explain the three different pinouts available?
The only remaining question I think is which of the three SIO pinout
options was used for the DART. The difference lies in the port B signals,
one pinout omitted SYNCB, one omitted DTRB, the third connected TxCB
and RxCB to the same pin. I'm 100% sure DTRB was implemented on the
DART, so it chose either to omit SYNCB or share the clocks. So it's
either 29=RxDB 28=RxCB 27=TxCB or 29=SYNCB 28=RxDB 27=RxTxCB.
How long is your SIO datasheet? Is it sufficient for your needs?
Regards,
Mike.
Tilmann Reh
nearer the mark?
The SIO/0 is "most" compatible with the DART - except that the SYNC pins
of the SIO are RI inputs at the DART.
Take care that also all those registers and bits for synchronous
operation are officially missing in the DART (don't know if they are
there, however).
there, however).
In the past I have plugged a DART in place of an SIO, and used it
successfully for sync (SDLC) communications. Hence at least some
parts marked DART contain the full logic of an SIO, give or take a
few manufacturing defects. They also used to market the SIO/9, in
which only channel A worked.
Mike.
bonzer
The datasheet does give the different pinouts for each version of the
SIO ie. SIO/0, SIO/1, SIO/2. It runs to about 20 pages and does seem to
cover what I need to know. I also have a book that explains programming
the Z8530 SCC which looks like it has some similarities to the SIO ic.
Matthew
