DC Cable Size question
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
It depends on how much resistance 22.9 m of cable has. What the heck is "bi-metal" speaker wire? Copper-clad aluminum perhaps? I would use 18 AWG copper zip cord.
OK, first thing, is it 14 strands per conductor, or 7 per conductor?
Let's assume it's 7. So the cross-section is 7 * 0.16 = 1.1mm^2 so the effective diameter is about 1.2mm
The resistance of this is probably something like 0.017 ohms per metre. The total length is about 46m, so the resistance is around 0.78 ohms.
At 0.16A, the voltage drop will be 0.13V. That's probably not significant.
Quintrex4
Oct 17, 2014
4
Great! Running off limited information from the suppliers site. 0.13V drop is insignificant for what I need it for.
Thanks for your help.
That assumes it's copper. For aluminium, the resistance is just under double copper's.
The voltage drop will probably still be under 1/4 of a volt.
