DC Motor Booster
nwaste
Aug 15, 2005
54
I mount from electric dril DC Motor to open my door, which is too slow (900 rpm). I need a booster with some FETs or somethin to speed it up.
Please Help
audioguru2
Apr 6, 2004
12,022
By boosting the drive power to the motor, it will be overloaded. Then the door opening quicker will help blow away the smoke! ;D ;D
MP1
Dec 7, 2003
3,397
If we had a diagram of your device, one might suggest changing the gear ratio so that you get faster movement. However, when you increase speed with gears, you lose torque. Not sure if you have enough reserve power from your drill motor to do this or not.
If you are powering the drill motor from the same supply as used on the drill, you will not want to increase current or voltage. It is most likely already using it's maximum capability.
Another alternative is to get a motor with a higher rpm rating.
MP
