issue with homemade DC motor + hall effect sensor
Soremade
Jun 10, 2026
3
Hi everyone,
I'm building a brushless DC motor for my students but I have an issue.
The tutorial I followed :
I recorded the issue right here :
We can see that the motor does not rotates entirely. I suppose the hall effect sensor does not send the order at the right moment but I don't know how to solve it. Any idea ? I'm quite frustrated cause I feel close to the goal.
The circuit I did is attached bellow.
Thanks a lot in advance,
Guillaume
Alec_t
Jul 7, 2015
3,821
Have you tried re-positioning the Hall sensor?
bertus
3,882
Could there be a problem with the mosfet.
It has a gate voltage threshold of 2 to 4 volts.
An irlz44 has a threshold voltage of 1 to 2 volts.
Bertus
Alec_t
Jul 7, 2015
3,821
I wondered about that, particularly as the circuit has no back-emf spike protection for when the coil current switches off. However, the power supply in the video shows switching between 0 and ~140mA, so presumably the FET is doing its stuff.
Soremade
Jun 10, 2026
3
Thanks Alec, yes I've tried many different position with the sensor.
Unfortunately Bertus I won't be able to check that point before next week but thanks for your suggestion.
bertus
3,882
Is the orientation of the magnets (north / south) correct?
Is the polarity of the coils correct (is one of the coils the wrong way around)?
Did you try to hold the hallsensor the other way around?
Bertus
Soremade
Jun 10, 2026
3
Hi everyone,
Thanks again for helping.
I tried repositioning the sensor in all the the ways but the one in the video is the one that works the best.
I suppose that the magnets orientation and coils polarity is good since when the coils are turned on, the magnet always return to the same position.
I checked the voltage going out of the sensor, it's 2,2V so it should work well with the mosfet.
Any other idea ?
bertus
3,882
With 2.2 volts there is a possibility that the mosfet will not turn on, as the gate threshold is between 2 and 4 volts for the irzf44.
An irlz44 will likely have more success.
Bertus
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
The A3144 has an open-collector NPN transistor output. This needs to be directly collected to the MOSFET gate input and pulled up with a resistor connected directly to the +5VDC supply. That will guarantee there will be enough voltage to drive the MOSFET fully into conduction. Have you made any voltage or oscilloscope measurements on your circuit? It looks like your are trying to use the permanent magnets on the rotor to actuate the Hall sensor. That's okay, but I would be using the Hall sensor as the clock input to a logic circuit rather than trying to use it to turn the series-connected electromagnets on and off. You probably also should reverse the polarity of the electromagnets at the appropriate positions of the rotor, twice per revolution. I don't think you can do that by simply turning the electromagnet current off and on.
