I'm trying to repair an automotive emergency tire inflator. I know this device probably isn't worth repairing, but I'm using the scenario to better understand the electronics involved.
When the unit is assembled, the motor turns, but never develops "normal" RPM. Occasionally, the relay that appears to drive the motor will click/chatter and the motor won't spin. Tapping the relay when it is clicking seems to help the relay latch. If I remove the motor from the gear assembly, it seems to turn at normal speeds.
With gear assembly attached, voltage at motor bounces between 1v and 1.5v
With gear assembly removed, voltage at motor is steady at about 7.4v.
I attempted to power the motor directly with a benchtop power supply, set voltage to 7.5, current to max, with gear assembly attached the motor still behaved the same. With gear assembly off, the motor runs to full speed, draws about 1a @ 7.5vdc.
I appreciate any feedback. My guess is that the motor is failing/failed, and that it shouldn't see such a dramatic voltage drop under load. I've just never experienced a motor failing partially, and the clicking relay made me wonder if a relay can somehow cause a downstream partial failure of a motor. (I also though a relay would either work or not work)
