Decade voltage regulation box
Pexy
Feb 21, 2016
142
Hy I was wondering if it's worth and if it would be usefull to build a decade voltage regulator box that you could change output voltage regulation for example 3,5,9,12V using n-way switch(n=number) and a few voltege regulating circuits.
shrtrnd
Jan 15, 2010
3,902
What is your amperage?
There are plenty of selectable wall-wart adapters available here in the States for cheap.
Unless this is some high amp application, and you just want to use it for low amperage circuits, I'd look around for the inexpensive pre-made selectable voltage regulators.
Pexy
Feb 21, 2016
142
It would be low voltages and for the amps im not so sure. I would use it to change fix voltages forom a fix voltages forom a computer PSU.
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
You can use a programmable three-terminal regulator, such as an LM338, and drive the programming terminal from a digital-to-analog converter to create a computer-programmable voltage output. Or use discrete transistors driven from logic-level outputs to select the output voltage:
Above schematic from TI datasheet for LM338.
Pexy
Feb 21, 2016
142
Thanks I will look it up and see what would be the best option.
