Need Help regarding the decade counter
Green
Mar 25, 2023
5
I'm new to this forum, sorry my english is not so good, just use a translator, and my knowledge about circuits and electronics is very low,
Here I want to ask for help from fellow forumers
Please help regarding the decade counter
For example clock input from ic555 t-on 30% and t-off 70%. see the example in the picture
If using ic4017 decade counter and activate 3 outputs, ouput from ic4017 such as A1, A2, A3
What is the easiest way to get outputs like B1, B2, B3, which only follows the T-on clock input
Hope fellow forumers can help me
Green
Mar 25, 2023
5
You could use an AND gate connected to the clock and each of the FF outputs.
Thanks crutschow, my knowledge about circuits and electronics is very low,
can you give a sample or diagram of how the AND gate is connected to the clock and each of the FF outputs.
crutschow
May 7, 2021
991
You just need one two-input AND for each FF with one of each of the inputs connected to each FF output.
The other inputs of all the AND gates are all connected to the clock signal.
Green
Mar 25, 2023
5
Sorry if i make mistake, like this picture,
I think not work
Green
Mar 25, 2023
5
Maybe I misunderstood the info you gave, especially the abbreviation "FF" output, I got more guidance from another forum, you mean like the diagram below
I think it would work well.
Thanks crutschow for the feedback given
I think my problem is solved.
Green
Mar 25, 2023
5
I update for reference, After searching for AND gates using transistors,
By using an NPN transistor as an AND gate, the voltage and Ampere ouput B1, B2, B3 can be controlled higher and wider depending on the input value or Vcc
And if the output value from ic4017 is enough, we can use only 1 NPN transistor to get the output B1, B2, B3,
danadak
Feb 19, 2021
1,104
Some questions :
1) What is clock rate from the 555 timer ?
2) What accuracy do you want in your timing ?
3) What pulse width you want for Bn outputs ?
Regards, Dana.
