Delaying a Serial Digital Stream
NS2012
Dec 17, 2012
10
I need your help please.
I'm trying to delay a digital serial stream signal for 50 to 100ms. How can I do that? Is there an exciting IC with such as functionality?
Here is what I'm trying to do: I have an asynch serial signal going to a device, I need to detect that signal on the source, do some processing before it reaches the destination. In order to avoid the signal reaching the destination before I finish my processing, I need to delay it a bit in order to achieve that goal.
Best Regards
CocaCola
Apr 7, 2012
3,635
I would use a micro with a circular buffer, assuming the data is a manageable amount for a micro to handle and buffer easily...
There are multiple ways.
One way is using a extremely long cable.
Another way is converting the signal to another slower moving form (say a surface wave on a ceramic) and then back to digital after that has taken a long detour.
Or you can sample the signal, store it as a bitstream, then recreate the signal
50 to 100ms is a long time. What is the data rate and is the digital stream sync or async?
NS2012
Dec 17, 2012
10
Thanks. I chose to store it in a bitstream then recreate it.
the baud rate is 9600b/s and it is a-synch.
Thanks again
