Dell Inspiron 1150
plexter
Have a Dell Inspiron 1150 notebook. some issue with the power adaptor.
It is beeping and and the Green led is flashing. I know how to test
everything inside the adaptor however problem is getting it apart.
Can't see any screws, and don't seem to be any clips on the sides.
Anyone know how to take it apart to see what the problem is with it.
jakdedert
Second the hammer idea. That's how I got mine apart. The Dell supplies
have thicker than usual casings. You probably 'will' damage the plastic
getting it cracked open. Also, be advised that these supplies are very
densely packed inside. Getting the cover off is just the first step.
You'll find the entire circuit wrapped in copper, which is
doublestick-taped on, and soldered. Once that's off, it's still
difficult to get around inside.
Good luck fixing it, but I concur with Jeff. Get a new pack...although
feel free to attempt a repair if you feel you're qualified (or you
haven't anything better to do).
jak
bz
Probably the cable is shorted near where it exits the case.
I have fixed several such supplies.
Hammer it along the seams.
Be careful, when it is live, some of that copper foil is hot and has high
voltage pulses running around on it. Can be a shocking experience.
bz 73 de N5BZ k
please pardon my infinite ignorance, the set-of-things-I-do-not-know is an
infinite set.
[email protected] remove ch100-5 to avoid spam trap
