Dell Inspiron 3521
MarkBob
Jan 6, 2022
8
On startup ticking noise (shorting ) and then gives a no media found .Have checked the hdd is fine .In the bios i get no hdd ,no dvd drive . Has anyone come across this before
bertus
3,875
Is the noise with or without the power adapter?
It looks like the HDD is broken.
Bertus
MarkBob
Jan 6, 2022
8
Bertus I have tested the hdd in another pc and it works fine thatwhy i seem to think that somewhere i have faulty component as both the hdd and dvd draw lights flicker for split second and then get the no hdd and no dvd in bios /no media found on black screen when not in bios
bertus
3,875
Perhaps a strange question, but are the fan and heatsink clean?
Dust can give a lot of trouble in laptops.
Bertus
MarkBob
Jan 6, 2022
8
All clean first thing i checked when opening the pc to see if i could see any physical component damage Bertus
MarkBob
Jan 6, 2022
8
Tried that already Harald Kapp ,new thermal paste too, bios is up to date
Martaine2005
May 12, 2015
5,318
Disconnect the HDD and DVD drive.
Boot the PC. (Laptop).
See if the ‘ticking’ is still there.
I’d try booting with the case off, it maybe easier to locate the noise.
Make sure the fan spins on POST.
Martin
14,317
You tried the HDD in another PC. Have you tried another HDD in this laptop?
Does the laptop perhaps have a second SATA port you could try?
If there's no valuable data on the HDD, you could try formatting it on the other pc where it works. Maybe a small error on the HDD which is ignored by the other pc but bothers the Dell?
Have you tried booting the Dell from the optical drive (if there is one)?
