Dell Laptop component level repair
Mike S
Does anyone have component level repair experience on laptops?
I've got a Dell Inspiron 8500 notebook computer with a charging problem-
The computer will run fine from the batteries until they are dead.
When plugged into the AC adapter, the BIOS gives an error message stating
that it cannot recognize the AC adapter, but it will power the computer. It
will not charge the batteries with the AC adapter.
The AC adapter has been confirmed good in two ways: the AC adapter powers
another identical computer with no problem, and another adapter gives the
same symptom.
When I plug the AC adapter into a Port Replicator and the computer onto the
port replicator, the batteries will charge.
The adapter input jack on the motherboard has been replaced, and I've
inspected the board as well as possible for a bad connection or faulty
components, but without a schematic of the power/charging circuit it's
nearly impossible to search for a fault.
The obvious solution is to replace the motherboard - again (this is my third
mobo in 5 years). I don't wish to invest another $160 in parts for another
temporary repair on this flawed design.
Does anyone have a schematic (longshot) or experience on repairing this
mobo?
Jim Yanik
problem- The computer will run fine from the batteries until they are
dead. When plugged into the AC adapter, the BIOS gives an error
message stating that it cannot recognize the AC adapter, but it will
power the computer. It will not charge the batteries with the AC
adapter. The AC adapter has been confirmed good in two ways: the AC
adapter powers another identical computer with no problem, and another
adapter gives the same symptom.
onto the port replicator, the batteries will charge.
third mobo in 5 years). I don't wish to invest another $160 in parts
for another temporary repair on this flawed design.
this mobo?
I suppose you could note down all the ICs in the area of the jack and
locate their spec sheets and find the one that regulates the battery
charging.
The spec sheets usually have application notes with typical circuit
diagrams.
jakdedert
same symptom.
mobo?
I'm guessing that the DC input jack repair was less than successful.
I think it's likely that one or more layers of the pc board are not
connected to the replaced jack. The charging circuitry appears to be
good, since the battery charges in the docking bay. I'd be surprised if
there was duplicate circuitry to recharge from that source, only a
different connection to the same part of the circuit that gets power
from the input jack.
Resoldering the DC jack might get it working again.
jak
Mike S
Jeff Liebermann said:
Look carefully at the connector on the adapter plug. There is an
outside metal contact. That's the ground. There's a concentric metal
contact ring on the inside, which is the +19.5VDC. There's also a
tiny center pin. The tiny center pin supplies some kind of handshake
with the computer that informs the computah that it's the right power
supply. If the center pin is broken somewhere, the handshake never
happens, and the computer complains that it can't identify the power
supply.
The most common point to break the center pin is in the plug at the
end of the power cable. The center wire is tiny and breaks easily.
Shove the laptop against the wall, bending the cable at a right angle
to the connector, and you've got a broken center wire.
However, since you've gone through the exercise of substituting power
supplies and verifying that they're good on a different Insprion 8500,
methinks that it's not the adapter. That leaves the power jack on the
motherboard, and associated circuitry.
Well, if it's not the jack or the connection, then there's a broken
trace somewhere. No schematic, no easy fix. Sorry.
3 boards in 5 years implies that you're doing something wrong with
this laptop. My guess(tm) is that it has something to do with the
docking station. I've had problems with those in the past. Perhaps
the order and sequence that power is applied or removed. Perhaps a
ground gets disconnected before the power. Dunno, just guessing.
<http://geekswithblogs.net/jjulian/archive/2004/12/09/17171.aspx>
(Note the docking station comments).
If you still have one of the old mother boards, you can possibly trace
out where the wire to the center pin ends.
Jeff Liebermann [email protected]
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 http://802.11junk.com
Skype: JeffLiebermann AE6KS 831-336-2558
Thank you all for your replies.
The other motherboards suffered different failutres (bad design) so I have
several full sets of power supply components to work with.
I don't think the problem is related to use of the port replicator because I
just started using it to charge the notebook now. Never used it with the
previous motherboards. The pinout of the adapter is helpful.
bz
Thats a cool trick. Sounds better than blasting it with a heat gun and
blowing other componenents off the board. Have to try it on some junk
boards and see how it works.
Build a dam around the component with paper. You can use a hot air gun to
remove or solder just one component, if you do things right.
bz 73 de N5BZ k
please pardon my infinite ignorance, the set-of-things-I-do-not-know is an
infinite set.
[email protected] remove ch100-5 to avoid spam trap
