Demodulation
vick5821
Jan 22, 2012
700
Any trustable circuit if I want to design a circuit that will demodulate an amplitude moduated(AM) signal ?
Any suggestion schematic ?
Thanks !
Needed for my mini project ^^
Need some guidance here :)
Thanks ^^
I think you need an electric guitar to do that :)
Yeah, for simplicity, start with a crystal radio.
From there, there are various things you can do to improve it. RF amplification before the detector is one. It should not be difficult to find resources for these on the web.
Electro132
Feb 12, 2013
261
Thanks !
Thanks ^^
Hey Vicki, i'm doing something similar but demodulating and then sending out through LED's. Want to work together? Let me know.
Btw, crystal radio would be a good choice to start. Siilar to FM i think ...
vick5821
Jan 22, 2012
700
Sure, but my project should end by mid of May HAHAHA
john monks
Mar 9, 2012
685
AM and FM are quite different.
AM is amplitude modulation where the carrier strength is made larger and smaller.
FM is frequency modulation where the carrier frequency is made higher and lower.
What I suggested is for AM only.
Electro132
Feb 12, 2013
261
That's fine. I'm working on a project along those lines at the moment so if you're interested or if you know someone who's interested let me know. I'm up to the part of storing energy into a cap as in like a Li-Ion battery so i can use it for other parts in my project.
Cheers
HellasTechn
Apr 14, 2013
1,579
Thanks !
Something like that with a preamplifier in the output maybe ?
Pretty much same as john's diagram
vick5821
Jan 22, 2012
700
I need a transformer ? Is your circuit is aplication of AM demodulation ?
TThanks
dietermoreno
Dec 30, 2012
238
A crystal radio can receive either AM or FM depending on the detector, and you would need different types of antennas for the higher frequencies used by FM.
CDRIVE
May 8, 2012
4,960
When you posted this it went right over my head but that was before I was enlightened! :)
Chris
vick5821
Jan 22, 2012
700
Chris
How am I able to do a AM transmitter and receiver ? My friend will be doing the AM transmitter and I am responsible for AM receiver. Any suggested circuit ?
No microcontroller is allowed
Urgent help neded :(
duke37
Jan 9, 2011
5,364
In the UK the rules about transmitting are very strict but some people do transmit VERY low power to activate old radios.
Google 'pantry radio' , some are valve based and some, more convenient, semiconductor based.
You will need to use a low frequency unless you are an expert so, run on medium wave and use a medium wave receiver. If you wish to build your own receiver I would suggest a TRF.
vick5821
Jan 22, 2012
700
I am doing for low frequency and low cost :)
For my lab work project ^^
Thanks !
14,487
Look at post #12 Hellastechn gave you the most basic and cheapest AM receiver possible !! :)
