Diagnosing bad motor
noquacks
Jun 26, 2013
148
People,
Have a 12v dc motor which operates a car headlight door (1987 Sunbird GT). I applied 12v directly from battery and it does not respond. Here is a link to the exact type of motor:
https://www.ebay.com/itm/313783539539?chn=ps&_trkparm s=ispr%3D1&amdata=enc%3A1rTenDbvlR4e-Zm19dRAHUA94&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=313783539539&targetid=1644837435243&device=c&mktype=&googleloc=1015197&poi=&campaignid=16743749222&mkgroupid=138744546207&rlsatarget=pla-1644837435243&abcId=9300842&merchantid=426122391&gclid=Cj0KCQjwmdGYBhDRARIsABmSEeP1UeSxh7hpoN89hWsRx1KIXg1WWK8ykpL6Fyb7tl6hJdFgqmGg-rMaAmiIEALw_wcB
Where would one begin in determining exactly what is the culprit with a no start/run motor? Brushes? Commutator? Other? I have no such experience, but am willing to try.
Thanks.
Minder
Apr 24, 2015
3,560
Firstly i would separate the motor from the gear-box and see if the motor is free to turn.
Then check continuity across the motor leads and also try a power source with the GB removed.
One of those procedures should turn up a possible reason.
noquacks
Jun 26, 2013
148
Thanks, minder. Good tip to start with. So, I popped offf the lower gear wheel, and applied 12v DC from the car battery. The motor did turn, which I was happy about, but man, what a loud screeeech. Yikes. What would cause that, and what to look for next to resolve the screech?
noquacks
Jun 26, 2013
148
Dry bearings?
How free is the shaft to turn?
Is the motor removed completely?
OK, I will remove the motor which is royal pain as it is so difficult for these motors to drop back down between the 2 carbon "magnets". Guess I have no choice, so here it goes.......
noquacks
Jun 26, 2013
148
Shaft does turn freely, with squeak, for the record.......
noquacks
Jun 26, 2013
148
Opened it up, and so much gunk inside. Cleaned it up with brass brushes, solvent, etc. Applied some oil in key spots, and had help holding back the brushes to drop the commutator back in. Now motor spins great! Clockwise, and also c-clockwise, as these motors spin both ways.
Now, after installing it in the car I have a bigger problem- the headlight actuator dos not respond to the light switch in the cab. So I have to troubleshoot the circuitboard. I repaired this a while ago with the help of members here, so be on the lookout for me and this project soon!
Thanks, people.
kellys_eye
Jun 25, 2010
6,512
The fact that the motor was seized would very likely cause the supply fuse to blow so that would be the first thing to check. If someone put in a higher rated fuse (unsurprisingly this is a common practise even though it's completely wrong) it may also have caused the operating switch to burn out. Worst case would be a burned out cable.
Check for dead relay...just about everything in autos is under relay control, especially motors.
