Disable Shutdown, Magnavox TV/VCR CCT132ATO1 (Symphonic TVCR13E1)
Brad
I replaced C604 & C626 both 33uf 10V (low cap). B+ reads 117V (power
off), then at power up, drops to +112V (normal) for about one second, and TV
shuts down. Note: HV measured around 22.5KV when set turned on, but not long
enough for screen to light up (shuts down). I don't have SM for this set.
Either a problem exists in the safety shutdown circuit, or there is an outside
"trigger". Note: There is vertical and horizontal deflection activity. VCR
mech. is not the cause because VCR wasn't used when problem started.
Can you tell me how to disable the shut down in order for me to make more
tests?
Thanks in advance, Brad
Before you type your password, credit card number, etc., be sure there is
no active key logger (spyware) in your PC.
Art
Are you sure the VCR mecha is not shutting the thing off?? If the
mechanical alignments within the vcr are not in the correct position per the
mode switch these units will shut down.
