Discrete Current Boost/Pulse circuit
N
Neil
I'm seeking help to design a discrete BJT current boost circuit which
can source a 600ma pulse for a duration of 200ms.
Any help would be great...
Thanks.
-Neil
Tim Williams
Over what voltage range? Is current only forward?
Tim
Rich Grise
I'm seeking help to design a discrete BJT current boost circuit which can
Thanks.
At least this year, they're getting started on their class projects
at the _beginning_ of the term, rather than waiting 'til the last
minute. ;-)
Cheers!
Rich
Martin Griffith
Thanks.
-Neil
At what tyre pressure?
Martin
N
Neil
minute. ;-)
Cheers!
Rich
It's not a university electronics engineering project, or any post
secondary electronics course related material either.
I'm on my own on this one. OK.
-Neil
N
Neil
Tim
Tim, Well that would be between 10 to 12 volts.
Current forward only. Yep
-Neil.
N
Neil
Martin
Martin, Pressure?..this is a electronics related question, it's a 600
milliamp pulse at 200 milliseconds.
W
Winfield
which can source a 600ma pulse for a duration of 200ms.
Why do you ask for a "current boost", as opposed to
a current source, or mirror, etc. Do you possibly
mean a current amplifier, getting say 6mA IN, and
delivering 100x more or 600mA OUT.
What do you mean by the phrase, current boost?
Tim Williams
Then something like this will suffice.
/---o Current sink
R1 1k (1.2V) |/
Logic in o---/\/\----+-----+---------|
R2 | _V_ v
1k > | 2 x | (0.6V)
_V_ 1N914 > R#
_|_ GND
R3 = 0.6 / Iout.
Or reverse the transistor and diodes for PNP (change GND to +V).
A transistor like TIP29 should suffice. Actually, a darlington (TIP120,
etc.) might not be a bad idea, in which case you will need three 1N914's in
series. The transistor will need a small heatsink, as you will be
dissipating about 12V * 0.6A = 5W.
Rise and fall time will be under a microsecond. If you need faster, put a
470pF capacitor across R1 and use a faster transistor.
If you need more accuracy, you can use more base voltage (i.e., more diodes
in series, or use a reverse-biased zener instead), in which case R3 needs
to change accordingly.
You can also cascode it:
o Iout
2.2k (3.3V) |/
+V o---/\/\---+-----|
_|_/ |\
3.3V //_\ v (2.7V)
Zener | |
_|_ GND o To above collector
Again, flip if you need a source.
Tim
John Fields
Tim
1. When you say "current forward" do you mean that you want the
circuit to send current to the load (source current) or do you mean
that you want current to come from the load into the circuit (sink
current)?
2. How often do you want this current pulse to appear?
3. Is the amount of current to be determined by the load resistance
or by the circuit?
