Divide a clock frequency by N using combinatorial logic
bluemoon123
Does anyone know how a clock can be divided by N, using purely
combinatorial logic?
Thanks.
Tim Williams
Gosh, it's so easy I feel dirty even mentioning type D flip-flops.
Getting a regular, specified duty cycle (such as 50%) for odd N is up to
you, though.
Tim
TT_Man
you, though.
Tim
Perhaps the OP meant just using gates....
bluemoon123
Yes I meant using purely logic gates, without flip-flops.
John Barrett
a chain of flip flops long enough for your target N
a little extra logic to trigger the lead flip flop on both the rising and
falling edge of the input signal
xor the outputs of the FFs with N
nor the outputs of the xors
and use that output to drive an output FF and reset the input FFs
Don't top-post.
And you can't build counters without flip-flops - a counter needs to
remember data from the past, and that can't be done without some kind
of memory device, which is to say a bistable, also known as a flip-
flop.
You build counters from logic gates - which is to say, purely
combinational logic - so the point is essentially academic, though it
is tricky to build flip-flops that work reliably using off-the-shelf
logic gates.
John Larkin
Yup, I think so, just nand gates or something. But it will have to
have internal states, so some people might shout "flipflop!"
John
John Barrett
John
Another solution -- without flip flops this time !!
Clocked RS latches modified for edge triggering on the clock can be
cascaded -- would take N latches and you can pick off your output anyplace
along the chain to get any desired duty cycle. A clocked RS latch expands to
5 gates, and you'll probably need 2 or 3 more to make it edge triggered,
which gets you riight up there with the flip flop for gate count per stage,
but with the disadvantage of not using a counter approach which means many
more stages for larger N.
The question then becomes "just exactly HOW PURE" must the combinatorial
logic be. If you cant build latches or flipflops from gates, I dont think
its possible.
Just for grins -- here is a weird way to do it that just uses low level
gates + some analog components
http://www.wenzel.com/pdffiles/dividers.pdf
John Larkin
I think you can also just "walk" states through rs flops (or
equivalent feedback gadgets) on clock high and low levels, which is
not exactly edge triggering
its possible.
The LC on the dflop thing is cute!
John
Rich Grise
its possible.
I've gposted cheap trick under the same subject line on a.b.s.e - it's
out of the 7474 data sheet. ;-)
Cheers!
Rich
Rich Grise
Sure, it can be done. Just don't call your cross-coupled gates "flipflops"
- the professor will probably never know the difference. ;-)
(or you might lose points for coming up with a workable answer to what's
otherwise an impossible task, in which case "it's impossible" might be the
intended answer. ;-) )
Good Luck!
Rich
jasen
build an N-counter in logic.
Where are you studying?
bluemoon123
I was asked this question in a job interview actually. Thanks everyone
for your inputs.
Phil Hobbs
John
I agree--turning delay from a bug to a feature.
I built something similar to the rate-multiplier pulse swallower gizmo
in my first engineering job, back in (ahem) 1982. It used two
synchronously cascaded decade counters (LS161), and the rate-multiplier
chain controlled the carry input of the less-significant stage. That
dropped the jitter from 1 whole output pulse to about 0.015 pulses,
which was a big help, since I was phase-locking a VCXO off the output.
Cheers,
Phil Hobbs
Don Lancaster
Good Luck!
Rich
There is a simple way to build reliable flip flops from gates. You use
TWO flip flops per stage, a master and a slave.
The slave enters the change on one clock edge, and the master keeps it
on the other.
Many thanks,
Don Lancaster voice phone: (928)428-4073
Synergetics 3860 West First Street Box 809 Thatcher, AZ 85552
rss: http://www.tinaja.com/whtnu.xml email: [email protected]
Please visit my GURU's LAIR web site at http://www.tinaja.com
K
Ken Smith
Thanks.
How about this:
(1)
Using five 74ACT inverters, make a slightly delayed and inverted
version of the clock.
(2)
Using another ACT AND the delayed and inverted with the normal clock to
make a very thin pulse. The output of this AND is called OUT and is the
output of the circuit. Use a 3 input AND for this to leave an input I'll
call ENABLE below.
(3)
Invert the OUT signal with a 7404. Don't use ACT here.
(4)
Get a large number of TTL AND gates and wire them up to do the following
with the inverted version of OUT (I'll write !OUT)
Y = !OUT AND (!OUT AND (!OUT AND (!OUT AND ........)))))))))))))))))
This Y signal is the enable.
Richard Henry
Thanks.
I remember doing this back in the early days of PALs. I needed what
amounted to a small counter, and I had unused circuits in a non-
registered PAL on my board (16L8, I think). The boards were
wirewrapped between DIP sockets, so changing circuitry was akin to
crochet (I even used a crochet hook from the craft store to pull out
deeply-nested 30-ga wires). I found that if I cross-coupled a few
outputs I could get it to work like I needed. Only afterward did I
realize I had made "logic-only" flip-flops.
