DIY amplifier+loudspeaker
Man-wai Chang
I only need a very very basic speaker, powered maybe by AA batteries,
that amplifies the 3.5mm audio output from the iPod Touch.
Is this going to be cheap?
Could I just connect a small buzzer to it?
@~@ You have the right to remain silence.
/ v \ Simplicity is Beauty! May the Force and farces be with you!
/( _ )\ (x86_64 Ubuntu 9.10) Linux 2.6.39.1
^ ^ 16:33:01 up 8 days 42 min 1 user load average: 0.00 0.01 0.05
ä¸å€Ÿè²¸! ä¸è©é¨™! 䏿´äº¤! 䏿‰“交! 䏿‰“劫! ä¸è‡ªæ®º! è«‹è€ƒæ…®ç¶œæ´ (CSSA):
http://www.swd.gov.hk/tc/index/site_pubsvc/page_socsecu/sub_addressesa
Daniel Mandic
I would recommend a chinese product. You get more for the money, it's
finished (case) and plug&play ready with connectors, (electronic)
parts, cables, loudspeakers...
Headset is the better option, IMO. You can still hear the environment
but have your radio, sample etc. playing.
Man-wai Chang
Not cheap enough, I think. Something like US$2-3 would be great... :)
Wanna hear it while bathing. :)
^ ^ 18:33:01 up 8 days 2:42 1 user load average: 0.10 0.06 0.06
Daniel Mandic
You are at the source. 2-3$ (new).... why not.
Don Klipstein
Don't use a buzzer.
This sounds to me like a job for an entry-level DIY-er trying to work
with actual electronics to work with:
An LM386, specifically LM386N-1 IIRC, a "cheap-and-dirty" hobbyist
audio power amplifier in low power range and good for 6V and 9V use, 12V
with some care.
Use any 8-ohm loudspeaker at least 2 inches in diameter with 5V to 9V
power supply, such as USB power, a 5V regulated power supply, 4 AA cells
or a 9V battery. Even if you push things very loud, the LM386 tends to
survive and even the crappiest loudspeakers won't completely die quickly,
and most won't get damaged at all.
LM386N-1 is the version that Radio Shack sold, and fair chance still
sells. Radio Shack catalog number 276-1731, may not be available in all
stores. Other parts needed withy it may not be available in all stores.
I recommend looking for Radio Shack stores with 4 sets of drawers of small
parts, as opposed to 2 or some other smaller number.
The lead-free version is available at Digi-Key, get to that here:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=LM386N-1-ND
(Minimum order or falling-short-of-minimum-fee and shipping charges
apply.)
Datasheet for National Semiconductor LM386 is here:
http://www.national.com/ds/LM/LM386.pdf
Pinout (viewed from above) of LM386 is in the lower-right corner of the
1st page of this PDF.
The schematic of my favorite way to use this (simplest) is in the
upper-left corner of Page 5 of this PDF.
The capacitor mentioned as 250 uF can be larger, though I see little need
to use more than 1000 uF.
The capacitor mentioned as .05 uF can be the more-common .047 uF. I
have successfully used .1 uF, but I recommend staying in the range of
nominally .047-.1 uF.
If you want a loudspeaker to use with the LM386 that I especially like:
Radio Shack 40-1909. May not be easy to get now, may be obsolete. It's
very much an all-purpose lower-power 5" fullrange loudspeaker with fairly
decent efficiency and some capability of impressive bass response.
Put it in a box of about shoebox size and made of wood at least 1/2
inch thick - amazing even without a port. Bass response is rather decent
in a .23 cubic inch box against a wall, with -3 dB at 108-110 Hz. It even
works well in a .125 cubic foot box - -3 dB is at about 120 Hz. In a .1
cubic foot box, its -3 dB bass point is about 126-127 Hz.
In a .63 cubic foot box with port tuning of 62 Hz, the bass -3dB point
is 53 Hz. That is good bass response for a box that size with 91 dB @
1W, 1m with a fullrange or woofer of any size.
Details including box and port dimensions at:
http://donklipstein.com/1909.html
Man-wai Chang
^ ^ 17:15:01 up 9 days 1:24 1 user load average: 0.01 0.02 0.05
Jasen Betts
Wow, they still make that?
yeah, (as long as you don't try to get them from mouser! all the others
have em, even Rat shack.)
Man-wai Chang
After a bit of search, I really found a HK$15 speaker in a famous Sham
Shui Po street of Hong Kong. The invoice said it's a Sanyo, but I failed
to find that word on the silver label behind the speaker. Model Number
is SA-WSP001. Made in China.
The stereo speaker can be powered from USB or 3xAAA batteries. The
bundled cables and plugs are of poor quality. Anyway, it works.
I guess I would not need to build one for a while.
^ ^ 21:04:01 up 10 days 5:13 2 users load average: 1.01 1.03 1.05
Daniel Mandic
Sham Shui Po street of Hong Kong. The invoice said it's a Sanyo, but
I failed to find that word on the silver label behind the speaker.
Model Number is SA-WSP001. Made in China.
1 and a half Euro :). You can can get a pair of 3.5mm headphone-jack
and 1m stereo-cable for that money here...
I have bought a low-level amp+speakers, made in China of course, for
100HK$. Full crap ;-) and one side of the speakers does not work, I
guess it's the jack socket...
Not for that money.
Man-wai Chang
That will be my next search! :)
Very very likely!
Not for that money.
A flat 8W speaker cone needs about HK$6 here.
^ ^ 22:45:01 up 11 days 6:54 1 user load average: 1.03 1.09 1.08
