Do a variable AC, high-amp power supply exists?
Roger Wilco
May 13, 2014
Hi!
I have been trying to find the tools needed for some experimenting with custom transformers and I can't find what I need. Maybe there is no such thing as a simple lab-equipment for this. I'm looking for a power supply with simple ways to change the properties below. With a push of a button :)
What I need is a AC power supply with ability to. (The numbers are just an example):
- Change the output frequency ex. 10 - 100> Mhz.
- High current ex. 20 - 100 Amp.
- Change voltage output ex. 12 - 230V.
If any one knows of a device like this I would be forever grateful!
Thanks!
duke37
Jan 9, 2011
5,364
You could modify a HF transmitter. You will need a BIG cable to feed the power into your house.
Hi!
Thanks!
I hope you have lot's of money.
Yeah, there are power supplies like this. I bid on one that was being sold locally, but someone else wanted it more than me.
I'll try to find you a link to the type of power supply I'm talking about.
The one I was bidding on only went for $250 or so. At the time I didn't need it enough to chase it.
Steve,
These will not do. Perhaps you missed this line in the OP?
14,487
Roger,
do you really need to go as high as 100MHz ? that's a pretty hefty RF transmitter!!
those ones Steve linked to go from 1Hz to 1 KHz
I think the original "requirements" indicated that the OP doesn't really know what he wants or is a little confused about what he needs.
I mean, sure, maybe he does want a 23kW 100MHz transmitter. But I wouldn't call that a power supply.
Yep, that was my point with my comment about having a lot of money. The requirements, as stated, were ridiculous.
