doubt smartphone battery
Status
Not open for further replies.
Kiwi
Jan 28, 2013
507
DROPPING THE PHONE WITHOUT A COVER WILL DEFINATELY SHORTEN ITS USEFUL LIFE! :confused:
Alec_t
Jul 7, 2015
3,821
Any covering on a phone will make it run warmer than if there were no cover (unless the cover is providing intended insulation from exposure to a heat source).
Unintended warming of electronic products should be avoided where possible, as it can shorten component life (albeit perhaps by not much if the warming is minimal) or cause them to malfunction.
gamer87
Mar 11, 2017
261
Does any accessory of this type have material that does not interfere with the heat dissipation of the smartphone, not reducing its useful life?
what is the best android app to monitor smartphone and battery temperature while charging and using that rubber or silicone accessory?
gamer87
Mar 11, 2017
261
What's the best tip or app to reduce battery consumption to the maximum automatically? There have been times when I left the smartphone on but with the screen off without using it for 3 hours and it reduced the battery by 30% but I wanted to reduce its use by staying only in the apps I use at the moment and when it is on without being used
i have a xiaomi redmi note 7
gamer87
Mar 11, 2017
261
no
Does turning off and on the smartphone constantly cause hardware damage?
14,317
@gamer87 : Simply accept that the lifetime of any component is limited. If you want to keep it in good condition as long as possible, then don't use it.
Another of those threads that lead nowhere -> closed.
Status
