Driving a transistor array
Larry Brasfield
Chris W said:
Will there be any problem driving one of these transistor arrays
http://focus.ti.com/lit/ds/symlink/sn75468.pdf
With these D-Type Flip Flops
http://rocky.digikey.com/WebLib/Texas Instruments/Web data/SN74HCT74.pdf
If you are demanding less than 500 mA sunk into each
Darlington collector, plan to drive their bases with an
HCT device, and don't expect saturation on the output
(or what might be called saturation for a Darlington), you
should be OK. Do you plan to use the logic output for
anything else, at the same time?
Chris W
I plan on driving either 1 to 4 LEDs in parallel, or a 12v around 2 or
so amp relay, on each Darlington collector. The flip flops will be
driving nothing else, just the Darlington array. I need 16 Darlingtons
so with 7 in a chip that will leave 5 unused Darlingtons on the one of
the 3 arrays or 1 on one chip and 2 on the others. I am still new to
all this. What exactly does it mean to have saturation on the output?
Chris W
Gift Giving Made Easy
Get the gifts you want &
give the gifts they want
http://thewishzone.com
Larry Brasfield
Upon closer inspection of the datasheet, I would revise
than collector current down to 350 mA.
I plan on driving either 1 to 4 LEDs in parallel, or a 12v around 2 or so amp relay, on each Darlington collector. The flip flops
will be driving nothing else, just the Darlington array. I need 16 Darlingtons so with 7 in a chip that will leave 5 unused
Darlingtons on the one of the 3 arrays or 1 on one chip and 2 on the others. I am still new to all this.
You had better be careful about burning up your
array(s) if you put more than about 150 mA into each
of the 7 devices in a package. The 2 Amps (or so) you
mention cannot be switched by just one of those devices.
Maybe you should be looking a power MOSFET rather
than a Darlington transistor array.
It means something a bit too involved to explain in all
its glory. For your purposes, the issue is: What will
be the voltage drop between the collector-emitter
terminals when the device is supposed to be switched
on? I urge you to consult the datasheet about that.
James Beck
I think he means that the relay is reated for a 2A load NOT that it
requires 2A to operate. Also, what in the datasheet leads you to
believe that the HCT part can't drive the darlingtons to saturation?
Larry Brasfield
I imagine you are right. But I've seen and
wired some pretty big relays.
Well, saturation is kind of a funny thing for the
Darlington transistor pair. The input transistor
can be readily saturated but the output transistor
is generally not saturated, having its base drive
modified such that its base and collector voltages
are about equal. So, using the term "saturation"
loosely to mean "as on as can be", there is no
reason the HCT device cannot cause that to
occur in the Darlington. But for the more precise
definition, requiring an excess of carriers in the
base region and a forward biased collector-base
junction, the output transistor certainly cannot be
brought to that state.
The reason I thought this might matter to the OP
is that Darlingtons often present a dissipation issue
in switching application due to their drop while in
the on state and that drop can be significant with
respect to the load voltage as well.
Chris W
To clarify, yes I did mean a relay that is rated for a 2A load.
I've been looking at that data sheet and I don't really understand a lot
of what it is saying. On page 4 it has the chart with all the values
and refers you to diagrams on page 5. Most of the diagrams say "Open"
by the output of the clamping diode. Doesn't that mean the Darlington
is off?
One line says Vce and has 1V typical for a 200ma load. Does that mean
that 1 volt will be dropped by the Darlington? If so I will need to
make a significant change to my voltage to drive my high intensity
LED's. For the 12V relay, that will probably have something more like
13.8 volts, it probably won't make any difference though.
I don't understand what the Vi(on) numbers are trying to tell me. For
the SN75469 in the MAX column they vary from 5V to 8V depending on the
collector current. What exactly does that mean? Is that the maximum
voltage the input line can handle? What about the minimum voltage
needed to turn the Darlington on?
Then the Vf for the clamp diode is 1.7V .... does that mean there will
be 1.7V drop from my supply?
Ii(off) seems obvious and Ii seems to be well with in what my flip flop
can provide. I assume Ir is the amount of revers current that will flow
for inductive kick back from a relay?
Finally what about Icex? Is that the minimum amount of current the
collector needs to stay on?
Thanks for everyones help. I really need to get a good book. The
problem is most books about things I am interested in are either way too
slow paced, or over my head. I learn this kind of thing very quickly
and often find beginner type books very slow paced.
Chris W
