Driving the base of a transistor with the output of a 4017
signalman72
Jan 26, 2014
57
Is it acceptable to just directly drive the base of a BJT(s) from the outputs of the 4017 decade counter, or should I use a resistor before the BJT? I plan on using the 3904. Thanks in advance.
No, generally it is not acceptable to do this in the normal "common emitter" configuration you'll likely use.
signalman72
Jan 26, 2014
57
Thanks for the replies. I used a 1k resistor before the 3904. I'm powering the 4017 with a 9 volt battery. The current draw of the 3904 with the resistor is about 6.5 mA, so I'm safe. Without it was a little over 20 mA.
