Voltage regulator driving a pass transistor...
Externet
Aug 24, 2009
944
Hello.
A 3 pin regulator with a maximum input voltage of 35V and 1 Ampere capable like LM7815 can drive a power transistor to raise its current capability. Does the input maximum voltage for the regulator also raises as the pass transistor Vce specifications ?
Or that input voltage increase only works for an adjustable as LM317 ?
AnalogKid
Jun 10, 2015
3,058
In the upper schematic it is the voltage between pins 1 and 2 that must be kept below the max spec. With pin 2 at GND, you cannot increase the input voltage above the datasheet spec.
In the lower schematic, it is again the pin1-pin2 voltage that is the issue. But because there is a zener between pin 2 and GND, this allows the input voltage from pin 1 to GND to be greater than Vmax because pin 2 also is above GND.
ak
crutschow
May 7, 2021
991
Note that the bottom circuit has poorer regulation and temperature stability, since the Vbe voltage of the transistor is not is feedback loop.
Externet
Aug 24, 2009
944
This circuit using a LM317 does not raise its rated Vin beyond 40V by the presence/use of a higher voltage rated pass transistor Q1; right ?
bertus
3,877
No, the bypasstransistor will not raise the input voltage.
Here are some pictures that use the bypasstransistor from a german magazine:
The resistor Rs determines when the bypasstransistor will kick-in.
With a pre-regulator you can raise the input voltage a bit:
The pre-ragulator will reduce the voltage accross the final regulator.
Bertus
crutschow
May 7, 2021
991
The pre-regulator could be just an NPN BJT or N-MOSFET configured as a follower with a Zener reference from the base/gate to ground.
