Driving Piezoelectric Transducers
George Gabriel
Hello to everybody,
as a part of my thesis work I'm trying to design a device for driving
piezoelectric transducers, to be used as a portable non-destructive
testing device.
I have lots of troubles in finding some good technical documentation
about probes. I'm quite confused so I think it's a good idea to ask for
help, before I'll go brain-dead.
I tried looking on several web sites of some serious producers of
piezo-ultrasonic transducers (like Panametrics-ndt) but I haven't found
detailed *electrical* information regarding a model I can use to
represent the device as bipole. Asking by email was hopeless too.
In a more detailed way:
The transducer is a wafer of piezoelectric material between two
metalized layers used as electrode for polarizing the active one (so
applying a voltage we can produce a thickness-deformation, in this case.)
The first-order equivalent model could be a capacitor; if we want a more
detailed characterization, we have to assume some RLC-series branch in
parallel with this capacitor to account for the multiple resonance
frequecies that the device shows.
The transducer will absorb a very low power from the driving device. I
read somewere (I can't remember) about 250mW.
Piezoelectric properties could be lost forever if the device dissipate
too much power in heat (If the temperature is over the "Curie
temperature" for too much time, we'll assist to a irreversible
depolarization of the piezoelectric layer.)
I wasn't able to find these informations and characteristics parameters
on the datasheet (ehr, I wasn't able to find the datasheet too) of the
probes I found, because producers usually assume that you'll plug these
device in yet-built pulser/receivers. So you'll not need these information.
I tried to do some "reverse-engineering work" to discover something
regarding those devices, looking at the characteristics of some
pulser/receiver (like those about Ritec or Panametrics-ndt) or power
amplifiers usually used to drive transducers.
I discovered that all those devices are assumed to be closed on 50 ohm
impedance.
Here is the origin of all my doubt!
Why they assume to close the pulser on a 50 ohm bipole, if the
transducer is modeled as a capacitor?
Have I to worry myself about that or it's just a normal "loading condition?"
Perhaps in the transducer is included a matching network so the
impedance we see looking in the bnc is just 50 ohm?
But it's quite strange, to me, because if this is the case applying a
200 V peak voltage, the power absorbed by the transducer is
P = (V^2)/R = 200*200/50=800 W
a rather huge power...
Perhaps the 50 ohm load is just a standard way to describing the
characteristics of the pulser, so I haven't any matching network?
But in this way we haven't any matching condition realized (nor maximum
power transfer, nor minimum distortion)
I'm really confused...
Is there anybody that knows links or articles about the information I need?
Thanks in advance for your help,
Pierpaolo
MK
George Gabriel said:
Hello to everybody,
testing device.
impedance.
Pierpaolo
Your simple capacitor model is no good at all when you are driving at high
power and want reasonable efficiency since this will usually involve
operating the piezo transducer at or near it mechanical resonant frequency.
There is a lot of tutorial stuff on
http://www.morganelectroceramics.com
start at
http://www.morganelectroceramics.com/piezoguide1.html
which may help you.
Good luck.
Michael Kellett
www.mkesc.co.uk
John Fields
Hello to everybody,
testing device.
Don Cleveland
Hello to everybody,
testing device.
Here's a link to an Apex app note that might help.
http://eportal.apexmicrotech.com/mainsite/pdf/an25u.pdf?guid=&item_id=&f_page=
Don Cleveland
Joerg
Hello George,
They need to be driven like transducers in a medical ultrasound system.
Basically there are two schemes, unipolar or bipolar. The lower cost
version is unipolar and it works well. A FET that can withstand the
required pulse voltage has its drain connected to a large positive
voltage via a choke. The drain connects to the transducer. Another LC
(or LR) combination can be used to get rid of the DC component on the
transducer. Now a brief pulse or a burst of pulses is applied to the
gate. It is important to drive this gate hard. The pulse length is
roughly compliant with the expected center frequency of the piezo. In
case of materials such as PZT-5 you can calculate that from the thickness.
As for voltage level it is not uncommon to pulse PZT-5 in excess of
100V. Please be cautious with these voltage levels. Especially at DC
these voltages can be very hazardous or even lethal.
Also, when sending bursts you have to mind the dissipation in the FET.
While Rdson might be low enough much of the losses there will be caused
by the slopes of the drive signal where the FET has to transit through
its linear region.
Regards, Joerg
George Gabriel
Thanks to all people answered me, now I'm reading the material with much
interest.
Expect new questions soon!
