When I check where the circle is I get 10.5V when I turn the power supply on and then it drops to 3.9 and starts falling. I get 0V where the square is.
For whatever reason I now have a steady 12V (VCAR) at pin 3 on U4 and 11.5V on pin 13.
Next move?
Rick
Pin 13 of U4(TDA3681J) should be GND,
are you counting correctly?
What is the voltage at pin 15 of U4 is it stable?
What is the voltage at the base of Q10,is it stable?
Rick,
Lets hope pin 15 is only 5V...![]()
" Using a Fluke DMM set on the diode setting we get .618 and .468 and when we reverse the leads they both read 0."
That should not be!
When you reverse the leads to the DMM it should read INFINITE! .618 is ok for the zener D2 and .468 is ok for the protector diode D32. Those are the forward voltage drops for the diodes.
Please measure voltages on IC4 pins 9,10,11
Base of Q10 is to high.
Please check Collector and emitter of Q10 as well
