dual opamp, only need 1?
AFex54
Apr 10, 2015
144
the circuit only needs one op amp,
I have lots of TL082s and im wondering what I should do with the unused op amp?
leave it be? or something else?
thanks
14,317
Never leave unused inputs of any IC open unless this is specifically stated in the datasheet. Connect them to defined potential, e.g. ground or Vcc. Use Pull-down or Pull-up resistors, this will allow you to easily repurpose these inputs in case you should want to use the unused opamp (even if you don't want to use it now).
Arouse1973
Adam
Dec 18, 2013
5,178
Op-amps are a bit different to terminate properly. You should always have feedback like a unity gain non inverting buffer and either connect the non inverting terminal to 0V for split rail PSU or mid supply for single supply PSU.
Adam
14,317
Of course, you're completely right there, Adam.
