dual switching power supply question
only_lonely
Jul 30, 2004
92
I have a motherboard, it can power up by 5V.
But i found it the only way i can power it and boot into windows is using parallel mode (master must in CV,slave in CC).If i want to see the current flow, then i need to sum the readings from master and slave.
If i use indepent mode (Master:CV) to 5V, it will auto restart when RAM shadows finished.Cannot boot into windows.
Can anyone here explain to me why???
audioguru2
Apr 6, 2004
12,022
You have two power supplies in a single case. One of them doesn't produce enough current so you must connect them in parallel but then must add the current readings.
Of course the pc will auto start when a single supply is used because it doesn't provide enough current.
Get a supply that can supply enough current.
only_lonely
Jul 30, 2004
92
oh i see. thanks.
but,may i know whats the theory inside the power supply series,parallel and independ mode?
mvs sarma
Feb 12, 2006
234
Hi
the CC mode is preset for a known constant current-- hence no need to measure.
if you are able to measure the total crt, you can deduct CC paramter and balance is taken by CV unit.
