DVD/CD platter widget
N
N_Cook
Bit of plastic ring with 3 internal springs and wedges that grips the disc
but comes off the metal spindle with the CD. Other than dot of superglue and
capilliary flow into the join , any recognised way of refixing? Reminds me
of those ex-juke box 45rpm singles with adaptor for home use
N
N_Cook
Arfa Daily said:
I always just put a tiny drop of superglue on the top of the shaft, and then
press the turntable back on, having first determined what the correct height
setting is, as the turntable tends to grip to the shaft very quickly ...
Don't overdo it on the glue though, as you don't want to press any down the
shaft and into the top bearing :-\
Arfa
I tend to find superglue is some sort of super-fluid , almost totally
lacking in viscosity and migrates along interference fits rather too easily.
As occuring in a laptop drive, the bearing would be only just below the
platter.
Meat Plow
easily. As occuring in a laptop drive, the bearing would be only just
below the platter.
But can't you buy gel?
Meat Plow
You can, yes, but the stuff I use comes on a card of like 12 tubes from
the local supermarket, and costs a coupla quid ($3). It works better
than all of the named brands, and is reasonably gloopy, whilst still
being a good liquid - if you see what I mean ...
To be honest, to be on the safe side, whenever I am glueing anything
close to a moving part such as a motor bearing, I tend to put a small
amount of oil or grease as appropriate into it. Then, if any superglue
does find its way by migration or spillage, it doesn't actually stick to
what it shouldn't.
Or just hang it opposite of the pull of gravity while the glue dries :)
N
N_Cook
Ended up with drop of superglue and capilliary and kept the platter spinning
for an hour with a small motor and O ring over plastic drive pulley. Didn't
like the idea of playing CD for that time as not sure what vapours would
come off in an enclosed space
