DVD drive to usb
Chasc
Jun 14, 2022
4
D3A74002-0B4E-418B-AC03-7EF67499AF8C.jpeg I have a old 5 1/4” DVD Rom SATA drive want to
Convert to USB looked on all the sites like eBay , Amazon how many others all have adapter for small 2.5 inch hard drives in laptop DVD which won’t work how the wrong size the dvd has 22 pin data and power see photo any help Where I can find on make an adapter would appreciate any help
Chasc
Jun 14, 2022
4
Sorry for the above error siri at it again corrected
Convert to USB I checked around did not find any adapters all I found was ones that work on small 2.5 inch hard drives and laptop DVD which won’t work its the wrong size the dvd has 22 pin connector.which is Data and power 15 pins are the power and 7pins are for data see the photo any help Find or make an adapter would be appreciate thanks for the help.
Martaine2005
May 12, 2015
5,318
These adapters work perfectly fine. I use them for external HDDs, DVD players and even a floppy disk drive!.
I have several of these adapters for SATA to PATA etc.
Have a read of this.
Martin
Chasc
Jun 14, 2022
4
Thanks for the information the problem I have is that most of the adapters Sata to usb are mini plugs they do not fit a full size 5 1/4” DVD they Only fit 2.5 inch drives and DVDs for laptops do you know where I can get an adapter that would work on a full-size DVD any help would be appreciated thank you Charlie
Chasc
Jun 14, 2022
4
You haven't looked at the example I linked, have you? This adapter has a pinout that imho matches your photo.
yes I’m looking for an adapter that pin out to USB the only ones I found are the mini plugs that fit 2.5 hard drives and laptop DVDs only do you know I can get one thanks
