Dvd recorder not recording sound
James Thompson
Hi I have a Dvd recorder with hard drive.
I also have Foxtel digital.
Anyway to cut a long story short.
I watch my Foxtel on AV2.
I watch and record to my dvd recorder on AV1.
Anyway suddenly when I record my foxtel, there is picture but no sound on
playback.
I thought it was a Dvd recorder problem, maybe a hard drive problem.
But I recorded some footage with my DVcamcorder to my DVD recorder hard
drive, and everything was ok, sound was there.
What could have suddenly gone wrong ?
All leads are in tight as I checked that.
Anyway very strange, any ideas on what could be causing this?
Thanks kindly
James Thompson
yep no sound when I watch foxtel through the Dvd recorder, but only on AV1,
AV2 i get sound, but I cannot see my Dvd recorder menu, this is viewed only
through AV1.
Dac
AV1, AV2 i get sound, but I cannot see my Dvd recorder menu, this is
viewed only through AV1.
There is your problem. Sound and video are seperate cables.
James Thompson
What ???? please be more precise ?
I know they are different cables ?
But why all of a sudden there is no sound ?
W
Wayne Reid
Describe EXACTLY what cables you have running between the Foxtel box and the
DVD recorder. What are the labels on the Foxtel box that they plug into, and
what are the lables on the DVD recorder that they plug into.
Have you had sound previously, or is this a recent thing? Have you changed
anything around recently?
You are the one asking the questions: You need to be precise, and to give
every bit of info if you want useful answers.
A couple of people have already had a pretty reasonable attempt to help you,
but you seem to have missed the points they made. If you provide the answers
to my questions then you will probably get some more detailed advice to
solve your problem.
What I do suggest is that you have a look in your DVD recorder's manual -
I'm betting that there's a picture of how it should be wired to a device
such as a Foxtel box (they may show a VCR as the example - but it will be
the same). You need a red/white/yellow composite AV lead, connected to the R
+ L Audio Out on the Foxtel box (red and white) plus the Video Out on the
Foxtel box (Yellow) to the R + L Audio In on the DVD Recorder (red and
white) plus the Video In on the DVD Recorder.
It's possible that the video signal is carried on an S-Video cable, but if
that's the case, you still need the red/white audio cables as S-Video cables
only carry a video signal.
WR
H
Hugh
The Foxtel digital unit has 2x SCART AV outputs on the rear. One has the
sound controlled by the digital remote control unit (mute and amplitude)
while the other output has sound all the time and cannot be adjusted.
Is it possible you are using both outputs and have the one with sound
controlled by the remote on mute going into AV1?
Easy to check, change the cables over.
