Dear all,
I have a digital circuit (ASIC) designed for some specific purpuses. The circuit works well in most cases.
However sometimes, it does not work i.e. I dont see any output.
I am investigating if this problem could be related to parasit capacitor at the input of my circuit.
The input of my ASIC circuit should be connected to the gorund by the user of the circuit.in order that the circuit does its job.
For some reason the ground is at a very close distance to my input channel (following image)
When the user decides to connect the input to the ground, he should use two metalic pins (connected to each other at one side ) and place it between the ground the the input.
Could you please tell me that in this case:
- Do I have a parasit capacitors?
- If I have a parasit capacitor, could it affect the input signal ?
- How can I measure if I have capacitance?
Many thanks and bests regards.
