This article of faith as you suggest (you might want to find a new line,
this one is old) is accomplished by 1800 degree burns, which gasify the wood
to burn clean and efficiently. My oil burner used to leave a reddish brown
stain on the roof that this unit does not.
http://www.woodboilers.com/wood-gasification.asp
The combustion system employed in Solo Plus boilers solves most of the
problems associated with conventional wood boilers and outdoor water stoves.
Here's why: The wood gasification combustion process in the Solo Plus boiler
begins when the small, quiet draft fan turns on in response to the boiler's
heat controls. The draft fan blows fresh air into the top of the firebox and
down through the wood and live charcoal bed. This hot air and smoke mixture
is forced through a slot in the top of the ceramic combustion chamber.
Super-heated secondary air is then injected into these gases. The
combination of the wood gas and smoke with the high temperature oxygen
results in a super-hot 1800° flame in the ceramic combustion tunnel. This is
the "Wow, that's unbelievable" process we call wood gasification. The gases
stay in this hot, turbulent environment long enough to achieve extremely
high combustion efficiency. The resultant heat passes into the vertical heat
exchange tubes giving off heat to the boiler water for house heating and
domestic hot water demands. The combination of optimum combustion and
maximum heat exchange efficiency is what yields the unusually high overall
boiler heating efficiencies of 80-85%.
