Electronic advise please ???
w_alhazmi
Sep 7, 2005
7
hi
I want help with this Project........
Design,buld and test an electronic circuit that will control 16 LEDs in different sequences.For example........,the LEDs could light from left to right,right to left,two at a time .The selection of sequence is to be made by push button.
im waiting for your a dvice
audioguru2
Apr 6, 2004
12,026
Using a microcontroller that you have programmed yourself would be the easiest way to perform the task. The microcontroller could even press the start button for you.
Using separate parts it would need an oscillator, an up-down counter, many gates and a few flip-flops. ;D
audioguru2
Apr 6, 2004
12,026
Hi Staigen,
I pressed your start button many times, but nothing happened. :'( :'(
audioguru2
Apr 6, 2004
12,026
Staigen said:
You didn't press hard enough!
I couldn't. I cut my finger when I was tying up my roses. :'(
Can't you make an automatic button? ???
w_alhazmi
Sep 7, 2005
7
thank you for your advise
Can't you make an automatic button?  ??? ??? ???
audioguru2
Apr 6, 2004
12,026
Good idea! ;D
Make an LED-blinker circuit with hundreds of vacuum tubes. It will keep you nice and warm in winter.
