Electronics Magic. What Excites You Now?
K
Kevin Aylward
Paul said:
I'm not your "maty" (sic) but can only assume that you took my remarks
as offensive.
Not at all.
I apologise if that was the case, as no offence was
intended.
Why on earth would what you say be considered offensive?
Just look at it this way: if everyone displayed your
attitude on this issue,
I think people need to chill out out a bit around here.
Kevin Aylward
[email protected]
http://www.anasoft.co.uk
SuperSpice, a very affordable Mixed-Mode
Windows Simulator with Schematic Capture,
Waveform Display, FFT's and Filter Design.
Rob Judd
Rick said:
I am still working on adding one of the ~80 watt CO2 lasers as an accessory
for my shizuoka cnc bedmill. I will use it to cut plastic and wood, and
engrave painted and annodized parts. Here is a pic of some 1/8" thick wood
that I just passed through the focused beam of a small synrad doing 17
watts:
http://www.skyko.com/luxar/synradm5.jpg
It just zips right through the wood, so you can imagine what neat items you
could precision cut or engrave if you hooked up a motion table under the
beam. I started doing that, but then purchased the used shizuoka bedmill
and figured might as well just bolt the laser onto it. I still have a
daedal 6" by 6" travel table with 200oz-in stepper motors and 5000 count
linear encoders, along with a couple of smaller CO2 lasers I would part
with, if you are into this type of thing. I am looking for a good used spec
analyzer covering at least 10Khz to 1Ghz *hint* *hint*
This is supposed to be about what excites you in electronics? Bah. I ran
a lasercutting business from 1984 until 1993 and every day I had to tune
the damned unstable things. Not the least exciting, mate.
I ran a 1220mm x 1220mm Strippit-Houdaille bed with a Photon Sources
450W head (530W on a good day, when the gas wasn't contaminated) and
eventually upgraded to a 1400W watercooled Ferranti. Both slow axial
flow models with catalytic converters. The latter would chew through
10mm mild steel at quite a speed, about 800mm/min from memory. Of
course, when you get to that thickness flame cutters are usually more
economical unless the edge has to be perfect for some reason.
It sure was exciting to me 20 years ago though.
Rob
Paul Burridge
So am I. I sold my last SA of this spec about a year ago and then
realised I'd made a big mistake less than a week later! :-(
I'd be interested to learn more about laser cutting, though. What type
and power of laser would be best suited to cutting out shapes in 5mm
thick aluminium/aluminum sheet?
Rick
Just learning more about rf while working with the 750 watt 81.36 mhz
generator is somewhat interesing. Your laser was probably a flowing gas
design, and you probably didn't work on the guts of it. CO2 lasers have
some very interesting electronics, from HV triodes, huge switching supplies,
honkin rf sources, etc. Funny how you can say you get excited by contacting
someone across the world on your homebuilt ham station when I can just pick
up my cell phone and call them.
Of course my real interest right now is diode pumped solid state frequency
doubled lasers, but I didn't want to get into explaining that much.
Rick
CO2, but you would need to be in the 200 to 400 watt range. A modern
solution like a coherent diamond (if they even go that high) is going to run
you more than a really fancy sports car.
Jeff
I'm bored. Need some magic. Lets hear it. What excites you now. (Related to
Michael wrote in message:
Clocks, especially ones that set themselves, but I also like my
boat-anchor-rack-mount Hewlett Packard Nixie clock.
Nixie tubes clocks are all the vogue again.
In the rare chance that any SED regulars are not IEEE members,
Spectrum has run a piece in "Tools and Toys" this month, reviewing a
GPS based nixie clock kit.
URL here:
http://www.amug.org/~jthomas/clockwork.html
Shameless plug -yes, it's my design.
Jeff
Rob Judd
Yes, it was a flowing gas design and yes, I did work on the guts of it.
Pneumatics, hydraulics, PWM ballscrew drivers, numeric control, vacuum
system, closed cycle refrigeration and all. I also wrote the CAD
front-end to the CNC on my trusty old Sirius I (Victor 9000 in the US)
microcomputer. So you see, I wasn't just an administrator.
The 25kV @ 5A power supply on the Ferranti was probably the scariest
thing I ever got close to as an electronics engineer. The original
Photon Sources laser head used Eimac triodes (4-400's from memory) as
ballast to keep the tubes in the positive resistance region.
Once you get involved with lasers there are some interesting peripheral
areas to investigate, but while you're running them for a living there
just isn't time. One that immediately comes to mind is holography,
another is time reversal effect experiments by shining interfering
lasers into a methane chamber.
I don't recall saying anything about getting "excited by contacting
someone across the world on (my) homebuilt ham station", and since I've
only just booked the ham license test I'm sure you must be thinking of
someone else there.
All the best,
Rob
Rob Judd
This is horse pucky. You can't cut aluminium any thicker than what can
be plated onto a fibreboard substrate with a CO2 laser, the surface is
too reflective at 10.6nM (the typical tuning frequency). For this you
should use either a turret punch or a waterjet cutter.
Rob
Z
Zak
Chris1 said:
Our neighbor here at work has a Trumpf 3000W "RF technology" laser. I've
used him a few times for prototyping, and he most definitely can cut
Aluminum with it. The thickest was only .062 thick. I don't know if this is
a CO2 laser or not. He did say Aluminum was trickier than steel, but I got
the impression it was due more to the low melting point.
3000 watt will probably have been a CO2 - unless efficiency of some
other type has gone up dramatically or he's got his own generating
plant. CO2 used to excel in efficiency, going above the 10% mark.
I wonder what happens to aluminum when you've made a strat with CO2. The
oxidized melt may have different absorptive properties than the glossy
metal.
Thomas
F
FEerguy9
electronics PLEASE)
Tony
Let's see if I can get this on one page......
Electronic electricity repository is an energy concept that aims to accumulate
and store electrical energy from any source. The storage would be intended to
accommodate such things as electric vehicles, home heating, etc. The best
example is the EV - an electric car that would run on an ever-accumulating
power source. That is to say, any and all sources of electrical energy --
including diffuse sources -- would be collected, combined and stored in the
form of capacitance. But, wouldn't the capacitor plates be bigger than the
vehicle? Well, yes they would, unless a way to increase the surface area of
the plates *within a small perimeter* could be fashioned. The plates (and the
dielectric) *must* match exactly, to gain optimum charge. I suggest that
Scanning Tunneling Microscope Technology, or possibly even nanotechnology be
used to accomplish this -- whatever could configure roughly halfway to the
molecular level. Doing this -- configuring massive surface area within a small
perimeter -- is the heart of eer. It could involve steps, or grooves to 'tuck'
the surface areas away. BTW, this would necessarily require a *much* stronger
dielectric, which admittedly is taken on faith - but it could be many years
away.
The object is to configure the plates and dielectric so they all fit like
Jell-O in a mold, and to make these all small in perimeter -- while yielding
enormous surface area. That way, it is hoped, enough charge could be stored to
run an EV. Further, it is expected that about 15 sources of renewable energy
(solar, wind, wave, etc.) would be able to contribute to the 'eer pool' of
stored electrical energy. In time, renewable energy stored in this way could
effectively replace fossil fuels and batteries for vehicles.
The renewable sources need not necessarily have a device actually *on* the
vehicle; it is anticipated that such renewable devices could be located, say,
in or on a garage, and the electric charge transferred to the vehicle when
required.
I ask you -- with the advent of electric cars, might not this concept (if it
worked) pretty much end our dependence on oil?
NOTE: This idea absolutely, in no way, breaks the Second Law! No more than a
12v car battery does.
Frank Lincoln
[email protected]
[email protected]
[email protected]
PS: In case you hadn't noticed, I am VERY weak with computers.
More, if you like..........
This is no more than a guess from a novice
Extra crispy revised edition......there are some mistakes in here
In one sentence, I am saying that a very, very advanced capacitor is possible,
and would accommodate most of the energy problems we have today -- basically it
would do the job that the energy function of oil now does.
An energy concept
Yes, there is a 21st Law of Thermodynamics. That is no knock on Faraday, just
a reference to the 21st century, and the new technology it has brought.
Simply stated, it is, "No energy concept involving renewables shall ever be
considered unless the word 'diffuse' is used, understood, and taken into
consideration."
Faraday could not have seen this coming. In his day, there was not the
multitude of diffuse renewable energy sources available, which can be converted
to electricity.
If human beings are ever to use renewable, natural energy sources, they will
have to take into consideration the diffuse nature of sunlight, wind, wave,
etc. I was actually surprised to find that Faraday, himself, used the word
"diffuse" in his writings. But, this was in reference to the spread of charge
on capacitor plates, and not the UN-concentrated free energy that is available
today for conversion to electricity.
There is NO way around this Law. By that, I mean that there in no way around
solving the "diffuse problem," before we are able to put renewable energy
sources to work in any effective way.
A goal......an idea......a prediction.......energy is easy........ there is no
crises.
We don't need oil.
We don't need batteries.
We don't need internal combustion engines.
We don't need fusion.
We don't need hybrids.
We don't need hydrogen-powered cars.
We don't need ethanol.
We don't need natural gas.
We don't need methane.
We don't even need efficiency.
We don't even need conservation.
All we need are the renewable energy sources that God - in His infinite wisdom
-- provided us.
Some could be used, some not. For a while. Eventually renewable energy
sources would be all we would need to power our EV's, and heat our homes. We
would have the luxury of choice, while at the same time powering our EV's with
them. All of them. Any of them. As long as they are able to generate any
amount of electricity.
To those who have read this before, and may have rejected it out of hand, let
me say that it is my strong belief that two major companies may be engaged in
pretty much the basic idea presented here. They have patents - I do not. In no
way do I - nor will I - attempt to claim any right whatsoever to this idea --
even though all my writing on it came from my own independent thinking for over
12 years. I wish them well. But, in case I am wrong about that effort being
made, I surely wish some interested party would help me connect this to the
people in government who say they want an energy solution. What they are
looking for is contained on this letter. I am THAT confident.
Note: I can see EER powering an automobile. That is almost a lock, in my mind.
Further applications are, perhaps, a little harder to deal with. Once a car
IS powered by EER, then all the entrepreneurs will take the rest to the logical
conclusion. For the most part, EER will be discussed in terms of an electric
vehicle.
EER in Brief
Electronic Electricity Repository (EER) is merely a concept at this time. There
is no business, no patent, and no money involved with this.
This involves solid state capacitors as a usable energy storage device for
electric vehicles, and other items. Conventional wisdom limits capacitors to
power surges, and the like. The full text of this concept will suggest a way to
make them fully competitive with the internal combustion engine, while not
violating the laws of energy density.
The easiest way to explain it is to use an electric vehicle as an
example. To power an EV with EER, an array of electronic devices --
perhaps solid-state capacitors, perhaps another device -- would
contain the electrical charge accumulated from a variety of sources
of electricity. Renewable energy sources are suggested, but *any*
source of electricity would work. With the questionable future of
battery-powered EV's, and fusion as an energy source, and the political debate
about fossil fuels, there are strong reasons to take a look at EER.
In fairness, many say it cannot be done. But, perhaps another war
-- or avoiding one -- could put the right minds to work on this concept. It
*would* provide a way to be independent of foreign oil, while providing a
structure for the transition to renewable forms of energy to power EV's - or
any other device powered by electricity.
This is merely a shell of an idea, but perhaps some further thought could help
bring it about.
Frank Lincoln....72430,[email protected]
A TRIP TO THE STORE IN AN EER POWERED EV
Let's suppose that the EER concept is fully developed, and built
into an electric vehicle. Let's also suppose that the newest and best
technological devices -- some of which are now being used in EV's - are
integrated into the vehicle's design. What follows is a description
of what might possibly have happened during an everyday trip to the store
in such a vehicle. (This assumes the use of an *advanced* solid-state
capacitor).
Ms. Jones notices her "fuel gauge" as she starts her vehicle; it
tells her that her microchip capacitor battery is 85% full. This means
that of the vast number of microchip capacitors in her "battery," 85% are
charged with their very small electric capacitance.
She proceeds to the store, and returns home -- a quarter mile
trip. As she pulls in her driveway, she looks again at her gauge. It
reads 84%. She thinks that she used only 1% of her battery capacity for
her trip.
But, she is wrong.
She used 10% of her available charged capacitors for the quarter
mile trip. So, why didn't her gauge read 75% when she returned?
There were several devices built into her vehicle which were
replenishing used capacitors, almost as fast as she was using them. (All
figures below are guesses -- just to make the point.)
1. The advanced solar panel on the roof of her vehicle was, as
always during sunlight, continuously recharging at a slow, but
steady rate. Because she had happened to drive and park in
the sunlight, the solar panel recharged 5% of her capacitors.
2. The air scoops arranged in her vehicle's design -- although
accounting for some drag -- were directing the air through
small dynamos, which recharged another 2%.
3. The regenerative brakes on all four wheels replenished another
2% of the capacitors.
So, she did, in fact, use 10% of the available capacitor charges,
but 9% were replaced by the activity of her trip.
This is nothing like perpetual motion; it is merely taking
advantage of the natural surrounding energy to replenish the energy
spent on the trip.
It is even conceivable that her "fuel gauge" might have read a
higher percentage upon her return; a shorter trip on a windier and
sunnier day, in a more sunlit route and parking spot, and many more
occasions to use the brakes, might have made that possible. The Second
Law of Thermodynamics is not violated, because energy from outside the
vehicle was being absorbed along the way.
It is noted that a battery-powered EV could have done much the
same, but the weight difference would have changed the percentages, so
as to defeat the purpose.
Frank Lincoln CS# 72430,2407
It is understood that high energy density is something that has been sought for
many years -- the concept is nothing new. What is suggested here is the
possibility that modern technology may now be in the position to actually
attain it -- to a degree that could combine the many energy sources (new and
old) into a common pool.
GIVEN:
- Trench capacitors, at the present time, have nowhere near the capability to
deal with the degree of energy that would be required in Electronic Electricity
Repository.
- The area of the plates in a trench capacitor will, for the most part,
determine the capacitance -- not exclusively, but this is the factor that is
dealt with here as having the most potential for improvement. It is assumed
that progress in the other factors -- dielectric strength, dielectric
composition, etc., will continue, and will accommodate the supposition of
surface area increase made here.
HYPOTHESIS:
- The surface area of a trench capacitor plate can be greatly increased without
increasing the perimeter, or the space required to store the capacitor.
- Etching a groove on the plate surface will do this, to a small degree, and it
is done, to some extent, today. What is surmised, here, is that, as the
technology allows, many cross-grooves could be etched *within* the first
groove. Then, with increasing precision, these cross-grooves could, in turn, be
cross-grooved. And, then those cross-grooves cross-grooved. Each successive
cross-grooving would be progressively smaller - magnitudes smaller. This could
be repeated until the molecular level was reached -- each time increasing the
surface area of the plate, and thus the capacitance. An inexact estimate of the
number of times it could be repeated is 26. It is surmised that each groove,
cross-groove, and, etc., would be matched by a ridge, a cross-ridge, and, etc.,
on the opposite plate, with corresponding shapes for the dielectric. The
resulting configuration would yield a perfectly matching set of plates
(sandwiching an appropriately shaped, and expectedly advanced dielectric). Such
a configuration and material composition may not be possible at this time, but
the direction of efforts in their respective technologies may lead to their
development in the very near future. This concept is put forth in
*anticipation* of those developments.
- In theory, each successive etching would substantially increase the area of
the plates, and thus the capacitance *without increasing their size*, their
perimeter, or the volume of space needed for them. Again, the only barrier
seems to be at reaching the molecular level, after each groove is re-grooved,
perpendicularly, and then THAT groove is re-grooved, etc. This would take
advantage of all the "inner space" available between the plate surface, and the
molecular level. (Understand that in place of "etching," Scanning Tunneling
Microscope Technology might be applied -- or even nanotechnology, if that ever
becomes reality. The point is to configure the grooves -- by whatever method.)
BENEFITS:
- An almost endless storage system for electricity.
- A way to store electricity from *any* source, from renewables to a wall
socket.
- A possible solution to the search for a better power plant for electric
vehicles.
- A structure within which to make the conversion from fossil fuels to
renewables.
- A way to accumulate the "trickle" of the many forms of renewable energy, and
combine and store them in a practical way; a way that could give strength to
the many "weak" and diffuse renewable energy sources.
An attempt to generally suggest HOW to accomplish EER will be made; this will
be based on the feedback received so far on this concept. For the most part,
feedback has come from various forums in CompuServe. All major objections will
be mentioned, and a way around each one will be suggested.
ENERGY DENSITY - This appears to be the leading objection to EER. In the
strongest terms, it is postulated, here, that there is no sacred or permanent
universal limit to energy density -- there are only hurdles. There *are* limits
to present materials and there *are* limits to a given geometry, but no
universal scientific boundary that would stand forever and always. There are
certainly physical limits to the materials *now* being used, but, this concept
of EER does, indeed, depend upon progress in this area -- improvements in
materials are bound to happen. Unless human progress is at its maximum, there
is reason for such an expectation. Especially since -- many say -- technology
is doubling every day with computer technology, and since many of the best
resources in the world are focused on this type of science. (If anything like
this concept of EER ever happens, it will be as a natural development of such
materials -- and NOT a result of this effort; that is quite thoroughly
understood.)
It is suggest here that even without improvements in dieletrics, there may be
opportunity to vastly improve their capability with the one factor -- geography
of the plates.
Just as computers changed everything about information, some form of EER may
change the way energy is dealt with. The suggestion, above, regarding etching
grooves in trench capacitor plates, and then etching those grooves, etc., is
offered as a possible way to provide the structure that would enable a
monumentally higher energy density, than has ever been achieved. If the
geometry of the plates is configured as suggested here, and they are
identically wrinkled, it is expected that a very high energy density could be
achieved by taking advantage of the inner space. The accumulation of a massive
repelling force between plates is a problem for which no answer will be
attempted here. But, mechanics aside, it appears that developing technology
will, indeed, provide the tools necessary to configure the plates.
CAPACITOR LEAKAGE - Two points here: 1) Leakage in trench capacitors is not
nearly as big a problem as it was a few short years ago -- holding a charge for
an electric vehicle, for example, would be well within the cycle of usage. In
other words, an EV would be expected to be used often enough to use the charges
before they have time to leak. 2) The percentage of loss due to leakage could
logically be offset by overloading the capacitor bank by a like percentage.
This is somewhat of a built-in inefficiency, but in time, wouldn't the leakage
problem be expected to continue to improve?
ARCHING - The concern about electrical arching between the extremely small
dimensions created by the etching and re-etching can only be explained away by
a layman in this way: the extremely small dimensions would occur between parts
of the same plate - and *not* between the opposing plates. The surfaces of the
two plates would remain equidistant over the entire area. It is expected that
the extremely small dimensions would mainly occur between points on the same
plate, at the same potential -- and, thus, no arching would be anticipated.
ATOMIC LEVEL - In a pretty thorough analysis in the LEAP forum, it was
indicated that "the whole idea of a capacitor thus breaks down as we approach
atomic dimensions." (The following assumes abilities predicted by some as to
etching, Scanning Tunneling Microscope Technology, atomic force microscope,
lithography, or other methods.) If you make one groove (G1) in a capacitor
plate, that certainly does not approach atomic dimensions, yet it does increase
the surface area of the plate (without increasing its perimeter). Then, if you
go back and make another groove (G2) WITHIN G1's SURFACE, you are closer -- but
still not near the atomic level. Then if the surface of G2 is etched (or STM'd)
with G3, you are closer yet; closer -- but still a long way from the atomic
level. How far? Well, the number 26 seems to hold up as the number of times
you could re-etch grooves, before you hit bottom.
(Each successive etching step would be, say, a hundred times smaller than the
previous one. G3 is a hundred times smaller than G2. G2 is a hundred times
smaller than G1, and etc. G26 would be the smallest, and would begin to enter
atomic dimensions.)
Now, backing up, let's say you made a hundred tiny grooves on the surface of
the original plate -- so you have 100 G1's. Within each G1, you etch 100 much
smaller G2's. Within each G2 you etch 100 G3's, which are yet, again, much
smaller. This is a million grooves at the 3rd of 26 steps. If you could
continue on in this way for 26 re-groovings of the grooves, how many grooves
would you have at the 26th step? And, by how much would you have increased the
surface area of that plate? And how much more dipole moment effect would now
take place? And how much more ability to hold charge would you have? If the
number 26 makes you cranky, stop at 20, or 12.
The point is this: there is a tremendous amount of "inner space" available
*before* you reach atomic level. Perhaps an optimum number could be safely
reached. Even 12 would seem to provide a monumental increase in charge storage
ability. Subject to mathematicians' scrutiny, there may be 10^24 grooves, when
you are only halfway down to atomic level, and free of the terrible things that
happen there. At the halfway point, you have monumentally increased the surface
area, without threatening stability. Assuming that the dielectric follows the
shape of the plate exactly, have you not vastly increased the number of
molecules subject to polar realignment in the electric field? Could it be said
that, even though the individual dipole moments would stay at the same in
magnitude, there is an opportunity to create a tremendously larger number of
them, by taking advantage of the inner space available?
MASS PRODUCTION - Some of these techniques to reform very small structures are
very slow and very expensive. Some question was raised as to their adaptability
to a mass production situation. As with any change in technology, first efforts
are not usually efficient. But there seems to be enough advantages to EER so
that the forces of supply and demand would push the costs down. Once in the
competitive market, improvements in technique could be expected.
GROOVES TOO SMALL? - A statement made in one of the forums was, "There is a
limit to how small the grooves can be before they don't work any more." As this
was from a good source, it is taken seriously. If some of the logic, above,
doesn't account for this, there may be difficulty, here.
DISCHARGE TIME - Capacitors normally discharge very quickly, so wouldn't they
make a rather bad storage device? No detailed answer will be attempted, here,
but can't this be controlled with a very low discharge current, with a high
resistance?
Electricity is -- or can be -- the common denominator for all energy sources,
from solar to hydro. It is for exactly this reason that EER could employ each
and every energy source. All the new renewable technology could be "fed" into
EER - without exception. Yet, at the same time, conventional sources could
contribute to it -- every drop of oil and every lump of coal on this planet
could be used, purposely. Could this captured energy not then be put to use, as
needed, and when needed, by controlling the energy bursts to simulate
conventional electricity flow?
The technology that would be needed for EER *seems* to be within sight - with
some faith required, perhaps, for the materials. Basically, it is the ability
to sculpt materials at the molecular level which brought about this revised
approach to EER. I have never seen the etching process, nor STM; this whole
concept of extremely small sculpting to obtain extremely high surface area is
drawn from my imagination -- and the little I have read about these processes.
I am motivated by the extreme advantages that would come about, and the
apparent ability to accomplish this; if not on a production basis, then at
least on a prototype basis, to start. I'm certain there are still technical
errors in this effort -- it is hoped that the general idea was communicated
with some adequacy. This *seems* possible - or within reach - to me, and it
*seems* as though it would bring about profound benefits, and it *seems* to me
that it is a logical way to approach energy at this point in time.
But, I defer to the experts.
I have no patent on this idea. My motivation is not monetary.
I understand that this could not be done today, because of limits on existing
dieletrics, and perhaps other items. My position is that EER is not impossible,
given advances in some technologies.
Please respond by Email
or call at (248) 288-3459
[email protected]
Frank Lincoln
Please keep in mind that EER would allow energy from any and all sources to be
stored and combined in such a way that an electric vehicle could, at some later
time, be powered by it.
Separating a steel sample using a tensile tester could be useful in EER.
The jagged edges could be cut off, just past their breakpoint. Call these two
pieces of jagged metal our capacitor plates. The broken pieces are matched
molecular for molecule. If a dielectric is molded between the two jagged ends,
the fit could not be better. "d" is maintained. The area of the matching jagged
edges is much, much more than the cross section of the steel sample. We then
have matching capacitor plates without using STM to configure all the surfaces.
Note: EER may not solve all energy problems, but in my opinion, it could
certainly power personal vehicles.
Anyone who receives this is free to publish.
[email protected]
[email protected]
