Delta Prime
- Jul 29, 2020
- 2,996
- Joined
- Jul 29, 2020
- Messages
- 2,996
You're thread your the boss.
If you have any other questions don't hesitate to ask....
but thank you anyway for the help. I'm getting closer to getting this monster back from the living dead.You're thread your the boss.
If you have any other questions don't hesitate to ask....![]()
A Necromancer,brings monstersbut thank you anyway for the help. I'm getting closer to getting this monster back from the living dead.
Well the language I was using earlier on when resoldering the wires back onto the larger transformer could be construded as talking in tongues , and summoning somthing from the depths! It got abit hot with the soldering iron....A Necromancer,brings monsters
Back from the living dead.
I like that!
We will be here for you...
I was , 400 degrees travels quickly up semi solid stranded wire.Be carefull...
O. K. Its your fault.(just kidding)now the fault finding can begin.
Yes certainly I am using a portable scope instead of my bench one , as I feared ground loop affect through the outputsO. K. Its your fault.(just kidding)
If possible, please provide a photo of the waveforms as well as your O'scope settings .
You're unit is Circa 1970's - all electrolytic capacitors must be replaced they literally dry up.
While i was on lunch I planned on getting some measurements from the outputs and there was some magic smoke coming from the back of the main board. , what I didn't notice a row of 4-5 transistors close too the edge of the board 1 of them was completely twisted round and bridging all 3 pins , I have a number of transistors in stock, so I might be lucky and the one that's in there crosses over to what I have. Ughhh....Yes certainly I am using a portable scope instead of my bench one , as I feared ground loop affect through the outputs
Presented one complete terrible picture of the offending transitor row , the one closest in the edge was completely twisted around. No clue how that happened I hadn't even touched the main board with my sticky mits yet. , possibly happened in transit as it was in bits when it arrived to me.If at first you don't succeed.
Do it, like the electronic engineer
told you to do it, in the first place.
